First, here is a pic of the stuff I am talking about: http://www.unistrut.us/index.php?WP=...isplay&P=po_mf
I called my local supplier and they have the 1 5/8" stuff and the 13/16" perforated stuff in stock. Each "stick" is 10 feet long, fyi. The 1 5/8" sticks are $28.40 each and the 13/16" sticks are $20.00 each. If your bar isn't 10' wide then you could even use the extra cutoff to act as braces between the long pieces of Unistrut to provide further support and load sharing. Both of these can hold an incredible amount of weight without much load flex. In fact, they are used to support really heavy air handlers in a lot of retail environments....just look at the ceiling the next time you are in Best Buy, Home Depot, etc. - the ceilings are chocked full of the stuff!
Let us know what you decide on doing!
P.S. - Maybe you can find a home for the iron by repurposing it as decorative touches somewhere (with a little reworking). Just a thought so the material is not wasted.
