AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Painting in-wall speaker frames/grills
post #1 of 7
About to start painting the room and speakers. Any tips on painting the actual speaker frame and grill? Any type of brush work better then others or should I spray paint them?
post #2 of 7
It's a pain in the ass when you have to use Latex. Luckily 5 of my 7 speakers were in Black walls/ceilings so I used a flat black spray paint. The other 2 were in columns and required latex. Use many, many, many very light coats otherwise you'll plug up the grills. If you can find a spray paint close to your wall color use it.
post #3 of 7
I assume you plan on removing the grill first.
Yes spray. Have a can of compressed air at hand and if you plug any holes blast away.
Several thin coats works best.
post #4 of 7
Also make sure to remove any possible backing on the grills. I have some Klipsch inwall's that have a felt like material on the back part of the grill. It wasn't removable so I tried to roll on the paint with a foam roller. It didn't turn out great since I had to go lightly to not clog up the felt in the holes. It left the inside of some of the hole perferations not covered w/ paint.
post #5 of 7
What I have found works the best out of anything is VHT, and Duplicolor makes vinyl & fabric spray dye. Its not a paint but an dye that soaks into the material (IE plastic, fabric, grills of speakers, ect..) and so if/when scratched the color doesn't go with it.
http://www.duplicolor.com/products/vinyl.html
- Josh
post #6 of 7
I used water to dilute the paint and did lots of thin coats. I actually dumped the mixture into a large casserole dish and dipped the grilles into a bath of the mixture over and over. It actually looks decent, but unfortunately my wife painted them the first time and clogged about 1/3 of the holes so I had to use a paperclip to poke each one though. Even now, I can still see some areas took better than other when viewed off axis, but I am the only one that really notices, or so everyone I ask says.
post #7 of 7
Ah yes...the inwalls I bought were white :
But now they're black :
As recommended here, I second spray paint in several light coats, so as to avoid clogging.
I removed the felt-like backing that came on mine as well, and also removed the drivers from the frame to paint it.
I also recommend spraying at several different angles to coat the "inside edges" of the grill holes.
