Sorry to jump in on this thread but I am experiencing the same issues.
I am building a HTPC with an Antec Fusion Black, Abit An-M2HD, AMD 4000. Hauppagge HVR1300 MCE with remote.
The main problem seems to be this God Damm LCD.
First problem - Fixed:
Pressing remote activates button twice:
First fixed by disabling EHome IR in Device Manager, actually realised that this was the MCE Remote Receiver IR Blaster so I disconnected it, I am not planing on using the Blaster to control any other IR device.
Second Problem - Not Fixed
LCD Crashes PC
After I installed the LCD and its Drivers after a while the LCD display would Freeze and the PC display would turn a white/grey with diagonal zig zags (a bit like the TV has gone out of tune. The only way to resolve this issue would be to unplug the PC Power - BAD TIMES.
It appears to happen when the LCD tries to display News or Weather, where the hell does it get the Info the web?? maybe mines not set up properly and that`s why its crashing, I am using Zone Alarm.
Third Problem - Not Fixed
The Display on the LCD is Low Quality
Covered in this post, the contrast on my LCD is as bad as the next guys, what`s the fix??
I have E Mail Antec on this issue as requested in similiar posts.
This is a very nice case that is dissapointingly let down by something that surely could be fixed easiliy, its a programmable display aint it so why can`t someone program it right!!!
LCD Crashes PC
Well if you just use that same model # I gave it should work fine. You can expect to run into some issues with the VFD. I suggest finding a MCE compatible USB IR receiver. At this point your best bet is using the USB IR receiver and putting some tape over the IR receiver on the VFD if you still want use of it. That way it wont crash.
