As exist a thread for the new V3000 its time for the W3000 to has her own thread.
UPDATE 2 28/1/2008
FULL SPECS AT SONY STYLE
40" MSRP PRICE 1.999$
http://www.sonystyle.com/webapp/wcs/...52921665116628
46" MSRP PRICE 2.499$
http://www.sonystyle.com/webapp/wcs/...52921665116630
52" MSRP PRICE 2.699$(ONLY TILL FEB 2 NORMAL MSRP 2999$
http://www.sonystyle.com/webapp/wcs/...tegoryId=28844
OWNERS MANUAL
http://esupport.sony.com/US/perl/mod...00®ion_id=1
CALIBRATION
http://spreadsheets.google.com/pub?k...w_BNwN--x3mCMQ
W3000 and XBR4/5 are pretty similar models except the 120Hz missing from the W3000.So XBR4/5 settings can be used also on W3000.The spreadsheet is creted to help with the various settings posted on XBR4/5 settings thread
Its available at 40",46" and 52"!
Exact specs:
Full specifications - Sony KDL-40W3000 Hide
Manufacturer: Sony Electronics, Inc.
Part number: KDL40W3000
General
Product Type 52 in LCD TV
Series BRAVIA
Digital Television Certification HDTV
PC Interface HDMI, VGA (HD-15)
Width 39.1 in
Depth 10.4 in
Height 27.1 in
Weight 55.1 lbs
Display
Diagonal Size 52 in
Technology TFT active matrix
Resolution 1920 x 1080
Display Format 1080p (FullHD)
Image Aspect Ratio 16:9
Image Contrast Ratio 2000:1
Dynamic Contrast Ratio 16000:1
Progressive Scan Progressive scanning (line doubling)
Widescreen Modes Full, Zoom, Normal, Wide Zoom
Viewing Angle 178 degrees
Viewing Angle (Vertical) 178 degrees
Comb Filter 3D digital
V-Chip Control Yes
Color Temperature Control Yes
Picture Adjustment Vivid/Standard/Custom
Additional Features Clock, Game mode, MotionFlow, Sleep timer
DVR
DVR None
VCR
Type None
DVD
Type None
Digital TV Tuner
Digital TV Tuner QAM, ATSC
Video Features
HDTV Ready Yes
Analog Video Input Signals NTSC
Input Video Formats 1080p
Freeze Memo Yes
Parental Channel Lock Yes
Radio
Radio None
Remote Control
Remote Control Remote control - Infrared
Supported Devices TV
Remote Control (2nd)
Type None
Audio System
Sound Output Mode Stereo
Surround Mode Yes
Sound Effects Virtual Dolby Digital, S-FORCE Front Surround Sound
Audio Controls Balance, Bass, Treble
Connections
Connector Type 2 x Component video input ( RCA phono ) - Rear, 2 x Composite video input ( RCA phono ) - Rear, 1 x Composite video input ( RCA phono ) - Side, 1 x S-Video input ( 4 pin mini-DIN ) - Rear, 1 x Headphones ( Mini-phone stereo 3.5 mm ) - Side, 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear, 2 x HDMI ( 19 pin HDMI Type A ) - Rear, 1 x HDMI ( 19 pin HDMI Type A ) - Side, 1 x Digital audio output (coaxial) ) - Rear, 1 x Serial ( 9 pin D-Sub, 1 x Audio line-in ( RCA phono ) - Side, 4 x Audio line-in ( RCA phono ) - Rear, 1 x Audio line-out ( RCA phono ) - Rear
Stands & Mounts
Flat Panel Mount Interface Yes
Miscellaneous
Compliant Standards EPA Energy Star
Power
Power Device Power supply - Internal
Power Consumption Stand by / Sleep 0.4 Watt
Power Consumption Operational 200 Watt
Battery None
Manufacturer Warranty
Service & Support 1 year warranty
Service & Support Details Limited warranty - Parts and labor - 1 year
Dimensions & Weight Details
Dimensions & Weight Details 39.1 in x 4.8 in x 25.3 in
In the attachment there is a picture of this tv.
SERVICE MENU
press the following sequence with less then 1 second between buttons (I.E. fast).
* [PWR OFF], [DISPLAY], [5], [VOL+], [PWR ON]
The TV will turn on in service mode and the screen will look like an old green CRT superimposed on top of the picture..
The ENTER key referred to in the directions below is the ENT key to the right of the "0" on the remote.
Screwing around in this mode is almost impossible without some reference manual, and you can really do irreversible damage to you TV if you start randomly changing values "to see what it does" .. so there I warned you, so don't come suing me if it gotten all screwy..
NAVIGATE IN SERVICE MODE
o [1] = Moves to Previous Menu Item
[4] = Moves to Next Menu Item
[3] = Adjusts Value Up
[6] = Adjusts Value Down
[MTS] = Toggles Stereo/Mono Audio
SAVE NEW SETTING
o [MUTE] followed by [ENTER] = stores NEW service mode settings to NVRAM
RESTORE USER SETTINGS
o [8] followed by [ENTER] = Restores All *USER* settings to factory defaults
RESET VALUES
o [0] followed by [ENTER] = Read Default service mode value from stored settings. (service mode reset)
LEAVE SERVICE MODE
o [PWR OFF] = Leave Service Mode any settings not written will be in effect until TV is unplugged or a Reset is performed.
RETURN TO DEFAULT SETTINGS:
o BEFORE storing NEW settings - unplug TV from wall, wait a few seconds, then plug back in, turn TV set on - All settings not written will have been lost.
o AFTER storing NEW settings - restore original value from list you made of original values before adjustments and store in NVRAM.
Thanks to arie
Alex the Great......40W3000, Jul 2007 - K-BMN-A-H-C-D-L-A-M
Malikriz................46W3000, Jul 2007 - K-BMN-A-H-C-D-L-A-M
rebel58................40W3000, Jul 2007 - K-BMN-A-H-C-D-L-A-M
Alex the Great......46W3000, Aug 2007 - K-BMN-A-H-C-D-L-A-N
petej88................52W3000, Aug, 2007 - M-BMN-A-H-C-D-L-A-N
RadarguyCT..........??W3000, Aug, 2007 - M-BMN-A-H-C-D-L-A-N
Dfigu....................40W3000, Aug 2007 - M-BMN-A-H-C-D-L-A-N
Continentqq..........40W3000, Sep 2007 - M-BMN-A-H-C-D-L-A-N
Apollo5.................52W3000, Sep 2007 - M-BMN-A-H-C-D-L-A-N
Apollo5.................52W3000, Sep 2007 - P-BMN-A-L-C-D-P-A-O
Grampy................46W3000, Oct 2007 - P-BMN-A-L-C-D-P-A-O
Zunit....................52W3000, Oct 2007 - Q-BMN-A-L-C-D-P-BMN-O
golbiga.................46W3000, Dec 2007 - R-BMN-A-EI-C-D-P-A-O
UPDATE 2 28/1/2008
OWNERS MANUAL
CALIBRATION
Exact specs:
General
Series BRAVIA
Width 39.1 in
Depth 10.4 in
Height 27.1 in
Weight 55.1 lbs
Display
Diagonal Size 52 in
V-Chip Control Yes
DVR
DVR None
VCR
Type None
DVD
Type None
Digital TV Tuner
Video Features
HDTV Ready Yes
Freeze Memo Yes
Radio
Radio None
Remote Control
Type None
Audio System
Surround Mode Yes
Connections
Stands & Mounts
Miscellaneous
Power
Battery None
SERVICE MENU
SAVE NEW SETTING
RESET VALUES
LEAVE SERVICE MODE
Thanks to arie
