Originally Posted by
bobloblaw
Can you expand on why this is the case? My understanding is that DVD video is stored on disc in Y'Cb'Cr' format (and output as Y'Pb'Pr' post MPEG decoder). Wouldn't you want to output the video signal with the leased amount of processing?
YCbCr has two color standards: 601 for SD and 709 for HD. We've found that A/V gear manufacturers are sometimes confused about what standard to use. Oppo does it correctly, but not everyone else does. RGB has only one color standard, so it is safer in that respect.
If the display behaves properly then there is nothing wrong with using YCbCr.
I believe the signal is converted to RGB in the display anyway.
-Bill
