Originally Posted by kellybob
...I think you will see there is quite a difference with the A/C polarity reversed. I have tested this with many components, and it makes a difference.
...The mere fact that the polarity can be reversed should tell you that it absolutely will make a difference. The only way for polarity reversal to not make a difference would be if it was not possible.
A/C is Alternating Current. The "polarity" alternates, or reverses, 60 times per second. You do not need to reverse your plug, because the power grid reverses it for you.
Just be warned that if you try to reverse the AC power on a component that has a grounded chassis, you will be in for a shocking experience. Your chassis will be LIVE...
- Touch the case, and you fry.
- Connect that component to another, and your equipment fries! (One chassis is Live, the other is Neutral, and the two short out with a BANG through your HDMI/coax cables).
Gary
