Originally Posted by Sitting Bull
Since Oppo has stated that their new Blu-Ray player will be the 980 with BD thrown in, I have a question.
Does the 980 natively decode the various Dolby and DTS options, etc., or does it off load this processing onto the AVR?
I ask this because I have heard, though not personally verified, that AVRs with Audyssey on board cannot handle the additional task of Dolby/DTS decoding at the same time, due to lack of processing power.
Any ideas folks?
Any ideas folks?
There is no limitation on standard DD and DTS audio with any AVR's/processors while using Audyssey.
The only one I have heard of is that some AVRs are limited with 192KHZ audio, and that the Audyssey is not functionable with it.
However, for most people 192KHZ audio is very rare.
Not all processors have this limitation.
I believe the DV-980H will decode standard DD and DTS, and as an option can convert that audio and output it as PCM.
The user can also choose to bitstream the audio and have the AVR/processor decode the audio.
Usually it's best to let the AVR decode it when possible.
So no more downmixing to 2 channel for me!
) that the multichannel mix has much less bass than the stereo mixes. Listening to other titles from Billy Joel and Five for Fighting, there is no lack of bass on the multichannel mixes, so I've come to the conclusion that it is just a difference in the mixes and there is nothing wrong with my setup or the 980H.
