AVS › AVS Forum › Video Components › DVD Players (Standard Def) › OPPO Digital Presents: DV-980H (1080p, SACD DSD, 7.1 Surround, USB 2.0)
OPPO Digital Presents: DV-980H (1080p, SACD DSD, 7.1 Surround, USB 2.0) - Page 212
post #6331 of 6353
quick question, my player will not play audio at normal speed anymore. It sounds like a chipmunk movie, like playing a 45 at 78 speed. This is playing cd's or movies and using either analog or digital out?
post #6332 of 6353
Does the video play normally or is it fast too?
post #6333 of 6353
Video is normal!
post #6334 of 6353
I'd suggest you contact Oppo direct.
blairy
post #6335 of 6353
Wow what a workhorse my 980 has been for over 4 years. I've had it in a wood burning (smokey) cottage during the winters, thrown it into my gym bag and into the trunk countless times, moved it around constantly and its never missed a beat (knock on wood and anti-jinx). Still amazes me how much it can be tweaked. Its ridiculous how many hours of use are on this thing. Since I don't watch tv, I do watch films everyday--the weekends a lot more, and this thing just won't stop working ! Thousands of hours and it works like brand new.
Its the little things that count as well such as the ability to turn off the display, remembering playback positions months later, etc etc. I may start stockpiling these...
post #6336 of 6353
I just bought one of these for next to nothing at Goodwill, but no remote was included. Does anyone know if the remotes from other Oppo family members will work with it? I can find those ones used on eBay, but not the 980H
post #6337 of 6353
Yes, all the OPPO DVD remotes are compatible.
OPPO Blu-ray remotes have multiple code set switches in the battery compartment, where code set 1 is the same as the original DVD remote, so those can work as well. OPPO sells them for $12. You might ask if they have any remaining DVD remotes.
-Bill
post #6338 of 6353
Actually, it's the backlit remote that is $12. The unlit model is only $8: http://www.oppodigital.com/proddetail.asp?prod=BDP80Remote. Plus shipping, I presume.
It's worth sending them an email to ask if they have any old DVD remotes on hand. You might get lucky.
-Bill
post #6339 of 6353
-Bill
Thanks, I just sent in an email question based on your info. I will let you know how it turns out.
GB
post #6340 of 6353
Well as it turns out, it's even a better deal than quoted above. I contacted their support people, put down very few dollars and now I have a new remote in hand!
post #6341 of 6353
Very good! Is it labeled 980H?
-Bill
post #6342 of 6353
There isn't a way to change the remote code of the 980, is there? I have both a 980 and an Oppo BDP-80, was able to change the remote code on the BDP-80 but couldn't find a way to do so for the 980, so the 980's remote always turns on the BDP-80 whenever I use the Power or Eject button.
post #6343 of 6353
Set the BDP-80 to code 2 or 3. Code 1 is the same as the 980 uses.
post #6344 of 6353
I already did that. The BDP-80 still responds to the Power and Eject buttons of the 980's remote.
post #6345 of 6353
Are you cutting power to the BDP-80? The players remember their remote code only when on or on standby (when the power light is red). The first time after a power outage it will respond to power on commands from all remote codes. After it powers up it learns it's intended code and will respond only to the correct one.
-Bill
post #6346 of 6353
I'll have to double check (its been a few years since I bought my 980), but I thought I remembered reading in the 980 manual about changing the remote code on the 980.
post #6347 of 6353
-Bill
Yes!
post #6348 of 6353
-Bill
Yeah, most of the components in my system have the power cut to them since they don't get used every day, so that would explain it. Thanks.
post #6349 of 6353
Hmmm....just looked through the 980H manual and didn't find anything. Perhaps I'm thinking of the 983? Or I just don't know what I'm talking about.redface.gif
post #6350 of 6353
It has an "Alt RC Code" setting which allows the player to respond to other brands of remote. I never used the feature and it's different from the 3 OPPO code sets used in the Blu-ray players.
-Bill
post #6351 of 6353
As I recall that was the only OPPO machine to play MLP audio files, making it valuable to a select few.
I still have mine but don't use it for that. I recommended it far and wide when it was in production.
Easy to make region free, plays PAL.
-Bill
post #6352 of 6353
-Bill
Definitely a workhorse. Possibly the best "discount" purchase I ever made.
Re-furb from OPPO 4 years ago. Never a problem. Except now. I just scored from OPPO a BD-93 and in my mind thought that I'd recoup some cost by selling the -980h along with the Pioneer BD-51fd. Really having a hard time convincing myself to let it go. Such a problem. Glad I got the -93 though, been drooling over the -93/-95 for years.
Just think what you might be able to do with the -980h outputting as direct source to a -103/105. Cool thing there. I do like the way OPPO thinks.
Maybe I'll keep the -980h up in a closet where the Boss won't notice!
giggles and grins,
Mkard
post #6353 of 6353
Originally Posted by dudley07726 View Post
I remember reading whereby some owners of the 980 experience the player cutting off the very beginning of an audio disc. I also have that problem.
Any fixes for that yet? Would appreciate the help.
I was wondering If there was ever a fix for this?
  Back to Forum: DVD Players (Standard Def)
