Originally Posted by
Rammitinski
Now that I think of it, I do have one problem - since the 11. update I lost the reception of the only analog channel I had programmed in there. Nothing I've done, short of wiping out everything, can get it back.
Is the analog channel still listed in your Channel List under Settings -> Channels -> Channels List?
If the channel is not listed, that would mean that Tribune removed the channel from their lineup, believing that it had recently gone off-air. If Tribune removed it, re-running a channel scan under Settings -> Channels -> Channel Scan would re-add it to your lineup, albeit without guide data.
To restore guide data to that channel, you would have to submit a
lineup change form to report that Tribune removed that analog station in error. This lineup change would not affect the ability to tune the channel or add it to the guide; it would only affect the availability of guide data on that channel.
Rammitinski
I remember reading something about analog reception being pretty much ruined by the update. True? (If so, it would suck, because I really want this channel, and if it ever goes digital, it won't be for a long time
Analog reception was not changed with the update, although reliability with analog channels certainly was. With the 11.x software, the analog tuners will periodically "go out" and are not restored until both tuners are set to digital channels. A reboot will also restore the analog tuners.
This makes the TivoHD completely unreliable as a basic/analog cable solution. This also presents serious problems for those with cable providers that do not yet offer digital simulcast (digital versions of the analog channels).
For some time now, TiVo has said they are working on a fix, but we don't know when that will be available.
