Originally Posted by
catmother
On several occasions when switching between a recording and tuner 1 and
tuner 2 there is no sound on tuner 2. Only switching tuner 2 channels
would restore sound.
Interesting, I'm trying to picture what you mean by this. By tuner 2, do you mean analog? I'm 100% OTA with both tuners only receiving digital signals and cannot recreate this problem
catmother
On one occasion, switching video output format from 1080i fixed to 1080i
hybrid worked but switching back to 1080i fixed (or any format) resulted in total loss of video
although the menus displayed properly. It required a reset to restore proper operation.
The TV is not at fault, swiching to HDMI1 connected to a Sony HDD250 displayed proper video.
I also cannot recreate this problem. I did lose video when I tried sending 480i material from TivoCast via HDMI, but it came back as soon as I went to 720p hybrid. So I wonder if you're having the problem with scaling analog stations. Also, this sounds much more like a HDMI issue - I'd not be so quick to blame the TivoHD for this. I'm not defending TivoHD, but blaming the people who made HDMI so much of a pain in the ass. I've had all sorts of problems with HDMI handshaking and use component except with my HD DVD player.
catmother
'Select' should not initiate recording. It is to easy to accidentally start a recording when the user expects 'select' to act as 'enter'
Recording initiation should be reserved for the 'record' key.
We'll have to agree to disagree here. The Select button is in the perfect location to start a recording...you can find it without looking at the remote. The record button is like a shortcut for recording, but I have to look at the remote to find it.
catmother
The Tivo should have a user selectable skip time, say 15, 30, 20, 120
seconds. like the HDD250/500 recorders. Even my Mits S-VHS tape recorder
has this feature.
They do! I'm a complete Tivo beginner and I set my remote to skip 30 sec at a touch of a button. What I really miss is the go to begining button, and a way to drag the current play location to a specific spot. Here's how you set the skip:
bfdtv
To enable 30-sec skip with the ->| button, enter the following key sequence while watching a recording: Select-Play-Select-3-0-Select. Note you will need to re-enter this code after a Tivo software update, and any time you unplug the TivoHD (or lose power).
Like the HDD250/500 a user selectable record buffer would be handy. The HDD20 has a choice of 15, 30 min 1 and 2 hours.
I believe they do, in a fashion. Just change the end time when you setup the recording. I do this all the time with Football games.
I agree that your first two bugs are definite problems that need to be addressed. They may go away if you use a component cable, but you should not have to do that. But the other problems you've listed with the Features seem like things you could get used to. The fact that the TivoHD has dual tuners and zero problems with getting accurate guide data, plus all of the really useful features like accurately recording new episodes, makes it worth while putting up with its minor quirks. With all the new shows starting this week and next, this is the perfect week to have dual tuners.
My wife almost always rolls her eyes every time I bring home a new device for my TV. After we've had the TivoHD for a few weeks, she said that this may be the the first good addition since I brought home a DVD player.
