AVS › AVS Forum › A/V Control & Automation › Remote Control Area › MX-1000 programming cable
post #1 of 3
OK, I got this Home Theater Master remote MX-1000 and it works and I downloaded the software and manual but have no programming cable. I thought that would be easy. I called to order one and they don't support it any more and can't give any info like cable specs. Does anybody know what the cable specs are for this or have one to sell ? I searched on here and the net but no luck. Thanks for any help.
post #2 of 3
It uses the same cable as the MX-700, 800 and 850. It's been discontinued for so long that the newer tech support people probably don't know that.
You can buy one of those from URC or build your own with the directions I've posted here.
post #3 of 3
Thanks for the info Mike. Exactly what I was looking for. I didn't realize it was as old as it is. Again, appreciate the help.
Dan
  Back to Forum: Remote Control Area
