HI everyone! I have searched AVS for a topic discussing my problem but cant find anything specifically related to it.
I have the ps3 hooked up to my 720p Sony 40" lcd hdtv (XBR1) and when watching planet earth on bluray - there are noticeable artifacts all over the screen. I mean, if you sit across the room they are very much less noticeable, but the image is still clearly not perfect and looks worse then when I watched that series on Discovery HD. Setting the ps3 to output 1080i instead of 720p changes nothing - same ugliness.
I was wondering if playing blu ray movies at 1080i or 720p caused there to be artifacts from the downscaling from 1080p 24Hrz or if I was as unlucky with the ps3 as I was with the 360 (fixed three times) and if I needed to take my ps3 back to Bestbuy for a free new unit.
I have looked all over AVS forums and cant find an answer.
SO - does anyone else here have a 720p or 1080i set and a ps3. IF so, what is your expereince with watching bluray movies? The only two BR movies i own are Planet Earth series and Mi:3. Neither look much better then HD cable, with PE having a lot of artifacts and Mi:3 being rediculous overly grainy, more so then how its suppose to look with that "film grain" effect they used.
Any help would be great - i am starting to feel like i wasted $500.00
Get a life...
