AVS › AVS Forum › Video Components › Home Theater Computers › Anything Wrong with my HTPC build?
post #1 of 12
This is probably the 50th PC Ive built over the years, but the first geared towards a specific task. What i plan on using it for is to rip/encode HD-DVDs (via 360 add on), DVDs, CDs, etc. Possibly add a tuner or 2 to record and catelog HD content. Honestly this feels more like a media server than HTPC since my initial plan is to use the 360 as a media extender to this HTPC, but if i find the performance to be flawless, I may use it directly. I plan on running vista ultimate 32bit.
This is what ive got in my newegg cart so far, let me know if you'd change anything.
Mobo: Gigabyte GA-965P-DS3
CPU: Intel e6750
PSU: Fortron 400 watts - Per suggestion
Mem: Corsair ValueSelect (1GB x 2)
Vid: Gigabyte GeForce 8500GT 256MB PCIe16
HD1: WD Caviar WD1600AAJS 160GB (For OS and Apps)
HD2: Barracude 7200.10 320GB (Picked this for best GB/$), i plan on adding HDs as i need them.
DVD: Sony NEC Optiarc 18x SATA (want the fastest ripper possible)
Give me your honest opinions.
Thanks guys.
post #2 of 12
Forgot to mention, i wont be gaming with this PC. Hence the 8500GT choice.
post #3 of 12
I think you should be fine for your goals.
I would add a good quiet HSF (non-OEM), such as Zalman, and Arctic Silver 5.
160 GB is a bit much for the OS and apps, should take no more than 30GB, so you might want to partition the first HDD and allocate some space for the media files.
post #4 of 12
I thought about getting a 34GB 10k Raptor for the OS. Any reason to do that instead?
post #5 of 12
I would like to add to this question.. Do 10k drives generally produce more/less noise than a 7200 or does it just depend on the drive? I have no experience with 10k drives if you cant tell.
post #6 of 12
I have no idea on the drive speed.
Do you think that a non-oem HSF is needed even if i dont plan on overclocking? Are people having stability issues with the stock fan?
post #7 of 12
If you want both speed and low db then pick up a 2.5" 7,200rpm drive.
A non-oem HSF will be good for keeping cool and quiet. I wouldn't bother with overclocking.
I'll also add that Antec power supplies are crap. See if you can pick up an OCZ or Fortron, those are quiet and reliable. I've had 3 Antec failed on me the last 2yrs. They make kick ass cases but the same can't be said about their PS.
post #8 of 12
I'm sure it will make much less heat as well.
post #9 of 12
Raptors are loud and hot, and expensive (per GB) but they are fast... seems to be close to about 2x faster then a 7200... but there could also be other factors involved...
post #10 of 12
i have a raptor 150 and to tell u the truth, for everyday use, it's not worth the extra $$$...i would not buy it again. It is noisy as well when it spins up at full speed. Your current setup in your first post looks good, i would setup a 30GB partition (this is what i do) for the OS and Applications, and use the rest of the space for media. It's always good to have 2 HDD's when encoding for the fastest speed, since you can encode to your 2nd drive so the same drive doesn't have to read/write (this is true for anything actually unraring etc).
I also wouldn't skimp out on the PSU, get a good rated PSU, i use seasonic m12 500, its modular and costs less than $100. You can get the non modular one for less.
what case are you putting all this into?
post #11 of 12
I havent decided on a case yet since i dont know my ultimate plans. So for now Im going to use an existing full tower ATX case i have. If I decide to use this as a dedicated HTPC, i will most likely get one of the Silverstone cases.
post #12 of 12
I'm very happy with my nMedia case.
http://www.nmediapc.com/product%201n.htm
