3/9/2008:
Here are some programs and results. All programs are being run on Vista x64 with sp1.
Current Conclusions:
For advanced editing, other than simple cuts:
Sony Vegas 8.0c, using avc format if want EXACT copy of original, with all the bells and whistles of advanced editing, otherwise, twice the file size and use MPEG2 30VBR.
Premier Pro, using avc format if want EXACT copy of original, otherwise mpeg2 25VBR to 30VBR as with Vegas, possibly even renders a little quicker than Sony Vegas 8 (though recent tests, i think these two are inferior to the ones in Sony Vegas 8, even with avc set to 17-21, it doesnt look as good as the original, nor does 25, but 30 may be close, when using mpeg2)
For simple cuts and combines
I'd use Nero 9 (nero vision 6.x) for this, it does a VERY fast job... Corel Movie Maker did ok on speed too, but a bit longer, with periods of not responding, and the final file crashes DVD architect, so probably avoid Core Movie Maker 7.
Nero 9 and pixela both are limitted to 99 clips that can be imported at a time.
For menus:
I'd use Nero 9, it does ok, otherwise DVD architect 5.x.
Other notes/ideas:
Pinnacle 12 was pretty close to the 25VBR with Vegas at 2m 36sec (see above), but Vegas is a much better editor, though the menus arent bad with Pinnacle.
The Tests:
Corel Movie Maker7:
Test: Fast export on i7
System: i7 920 at 2.66ghz 1333fsb on Rampage II extreme x58, Corsair Dominator DDR3 1600mhz 12GB; D drive/file save location on areca controller, 4x1.5TB 32mb cache drives, C drive is on the areca controller as well, a 500GB 32mb cache seagate, ATI 4870's
File used: mts from Canon HF10, 1min 23sec long, 159MB original size, 15.1mpbs out of 17mbps (avc, high@L4CABC 2 ref frames 256KB 2 channel ac3)
Time To complete: 38 seconds
Result file size and quality: 159MB/looks Idential to original, 33 seconds quicker than Vegas 8 Pro
DVD Architect compat: Causes DVDa to crash! ((set DVD architect to 18mbps))
Other notes: Program gets in a not responding state, when i import say 1hr 42 mins worth of canon clips, takes 7 minutes then unlocks
Pinnacle 12:
General Notes/observations:
**Bluray type; Mpeg2 image type.. closest match to original mts off camcorder
**AVCHD, either image type: some pixelation in pans, not visible in the original
***No smart rendering or transcoding, always have to render
**Full ability to have transitions and effects of course
Test: Took clip made AVCHD image and menu on dual core
System: Dual core machine - 1.86ghz (1033 fsb) on a P5N-T deluxe board with 1066 DDR2 ram with asus onboard raid5 4 drive array for saving the files
Time To complete: 29min 40 sec
Result file size and quality: 158MB / noticeable degradation pixelation
DVD Architect compat: NA
Other test: Tried using previously burned image from Nero and created disc, but couldnt play in stand alone player
Test: Render to BD AVCHD on quad
System: quad core is a t3400 dell with a 2.4ghz (1033 fsb) 800mhz ram with a single SATAII 32mb cache drive;
Time To complete: 11m9sec
Result file size and quality: Quality was worse than original
Test: Render to BD AVCHD type image on i7
Time To complete: 5m 40sec
Result file size and quality: 169MB (16/1)/ audio is only 192KB, quality is WORSE than what is done in Vegas PRO! Sound seems LOWER than original, rather bad, 30 sec longer than Sony Vegas render time at 20VBR
Test: Render to BDmpeg2 on dual core
System: Dual core machine - 1.86ghz (1033 fsb) on a P5N-T deluxe Asus board with 1066 DDR2 ram with asus onboard raid5 4 drive array for saving the files
Time To complete: 10m 10sec
Result file size and quality: Quality was near that of original
Test: Render to BDmpeg2 on quad
Time To complete: 4m15sec
Test: Render to BDmpeg2 on i7
Time To complete: 2m 36sec
Result file size and quality: 211MB (20mbps)/ audio is only 192KB, quality is not bad, comparible to say 20VBR sony **Sound seems LOWER than original, rather bad, 30 sec longer than Sony Vegas render time at 20VBR
Test: Render mov file as BDmpeg2 image on dual core at 1920x1080
File used: mov file from panasonic dmc-tz5, 1m 46sec long (1280x720p)
Time To complete: 5m 20sec
Result file size and quality: NA, Movs are very hard to edit in Pinnacle
Adobe Encore cs4
(doing transcode now, not creating iso image yet): took the 1m 23sec canon hf100 clip, original size 159mb, bitrate 15.1, set project to 1920x1080 bray type, at 20mbps project setting.. transcode at project settings took 1m8sec very similar to Sony Vegas in speed (i7 920 2.6ghz);
Adobe Premier Pro cs4
**Sweet spots here are probably h.264 at 20VBR or mpeg2 at 30VBR, though mpeg2 at 25 isnt bad
Test: Export to h.264 bluray at 17VBR, single pass, best, 4.1 profile, DD2.0
Time To complete: 3m 59sec (twice as fast as sony AVC, but not as good as original)
Result file size and quality: 219MB / quality is close to original, though some pixelation
DVD Architect compat: imports without recompression, audio needs recompressed with current render setting (set DVD architect to 18mbps for these Canon shots)
Test: Export to h.264 bluray at 20VBR+-5, single pass, best, 4.0 profile, DD2.0
Time To complete: 4m 10sec (twice as fast as sony AVC, but not as good as original)
Result file size and quality: 200MB / quality is close to original
Test: Export to mpeg2 bluray at 25VBR+-5 best, 4.0 profile, DD2.0
Time To complete: 2m33sec (about 34 sec longer time than the same VBR in Sony Vegas)
Result file size and quality: 251MB / quality is close, but not quite as good as original, 30VBR mpeg2 probably sweet spot but nearly 2x the original file size
Adobe Premiere Pro CS3
**Attempted to import both m2ts and mts, it didnt like the format
**MOV related: Added two 53sec mov files, exported back to MOV, took 2m25sec on Quad Core 2.4ghz (as fast as the export to mpeg with Nero Vision)
Sony Vegas 8.0c:
**Output to bluray: only option here that matches original is the mediaconcept 25mbps type (pan test showed maybe slightly more artifacts than the original, maybe; almost as nice as the pinnacle bluray mpeg or the nero 8 mpeg, probably the best mpeg2 is 30VBR
**# of rendering threads is 4 unless otherwise noted (in the options)
**Output to AVC m2ts or mp4 have the closest match in quality, if using AVCHD in subsettings, cant set bitrate higher than 16,000,000, if you use AVC, you can set it to say 17,000,000
** Tried the mainconcept mp4 AVC option, it was far worse than the Sony AVC, mp4 cant be opened in VMC
##lately getting exception errors when i try to export to either AVC or AVCHD (under sony AVC), not sure why!
Test: RENDER AS, mpeg2 mainconcept m2t at 16.5mbps+-5 VBR on i7
Time To complete: 1m 57sec (about 34 sec longer time than the same VBR in Sony Vegas)
Result file size and quality: 213MB / quality is somewhat pixelated, not best option
Test: RENDER AS, Mainconcept m2v MPEG2 at 25VBR on dual core
Time To complete: 12min (probably around 8.6 hours per 1 hour of rendered video on dual)
Result file size and quality: NA / pretty close to original, some pixelation
DVD Architect compat: no recode needed, separate audio render from Vegas
Test: RENDER AS, mpeg2 mainconcept m2t at 25mbps+-5 VBR on i7
Time To complete: 2m 9sec (second run was 1m 59sec, TRIED 8 threads in options, no speed change), this includes audio
Result file size and quality: 305MB / quality is pixelated, size 2x original, closest mpeg2 match short of 30VBR
DVD Architect compat: imports without recompression, audio included
Test: RENDER AS, mpeg2 mainconcept m2t at 25mbps+-5 VBR on i7 full 1 hour clip
File used: mts from Canon HF10, 1hr combination of clips (6.79GB original size) (avc, high@L4CABC 2 ref frames 256KB 2 channel ac3)
Time To complete: 1hr 21mins
Result file size and quality: 12.9GB / quality is pixelated, size 2x original, closest mpeg2 match short of 30VBR
Test: [/b] RENDER AS, mpeg2 mainconcept m2t at 23mbps CBR, best under video quality on i7
Time To complete: 2m 9sec (second run was 1m 59sec)
Result file size and quality: 234MB / quality is pixelated / fuzzier than orig in parts
Test: RENDER AS, SONY AVC mp4 at 16mbps, best for setting under video quality on i7
Time To complete: 3m 55sec
Result file size and quality: 159MB / Very close to original in quality
DVD Architect compat: imports without recompression, must create ac3 render separately
Test: RENDER AS, SONY AVC m2t at 16mbps, best for setting under video quality on i7
Time To complete: 6m 42sec (due to audio being rendered at same time)
Result file size and quality: 164MB / Very close to original in quality
DVD Architect compat: imports without recompression, audio is included in m2t
Test: RENDER AS, SONY AVC m2t at 16mbps, best for setting under video quality at 3.2ghz on i7
System: i7 920 at 3.2ghz OCD 1333fsb on Rampage II extreme x58, Corsair Dominator DDR3 1600mhz 12GB; D drive/file save location on areca controller, 4x1.5TB 32mb cache drives, C drive is on the areca controller as well, a 500GB 32mb cache seagate, ATI 4870's
Time To complete: 5m30sec (about 1minute faster Overclocked to 3.2ghz, must verify this )
DVD Architect compat: imports without recompression, audio is included in m2t, no audio recomp.
Other notes: Tried the mainconcept mp4 AVC option, it was far worse than the Sony AVC
Test: RENDER AS, SONY AVC mp4 at 16mbps, best for setting under video quality at on dual core
File used: mts from Canon HF10, This one is 23sec long, 15.1mpbs out of 17mbps (avc, high@L4CABC 2 ref frames 256KB 2 channel ac3)
Time To complete: 4m20sec (would be 15m 40 sec if the full 1m 23 sec for comparison)
DVD Architect compat: the mp4 said it needed recompressed in architect at that time i tried this
Test: RENDER AS, Mainconcept mpeg2 m2t at 25VBR, convert a MOV on quad core at 1920x1080
File used: mov file from panasonic dmc-tz5, 53sec long, 1280x720
Time To complete: 5m 12sec (roughly 11 minutes if 1m 46 sec long as with pinnacle test)
Test: RENDER AS, Mainconcept mpeg2 m2v at 15VBR with max of 38.8 low of 10, 31 on quality, best for video setting, render DVR recording 3hr 48min worth on i7
File used: Roughly 6 hours worth of mpeg2 video from firewire DVR (14.1mbps, max rate 38.8), original file size 24.5GB
Time To complete: 5hr 40min
Result file size and quality: 23.9GB (very close to original in SIZE and quality, best setting for CapDVS rips of DVR recordings)
DVD Architect compat: no recompress; would have to render the ac3 separately using AC3 pro in vegas
Ulead Video 11.5
*Wont import m2ts or mts files: Found that i had to use the video wizard for it to work:
**The to disc option wouldnt let me choose a local harddrive image instead, it was greyed out:
**I found that i could do the export to file option.. but the output was mpg.. and after 4%, 2m 34 seconds had elapsed on the quad core.. so i cancelled.. so much for fast rendering with this tool, at least via the file option..
*I found that the create disc.. bluray option allowed for the ability to send it to just the harddrive, it however, was taking way too long, so i aborted.
PowerDirector 7.0.1618
*No option for 1440 or even 1920x1080 avchd here
PowerDirector 7.0.1829
(Must change aspect ratio in main menu to 16:9, then full avchd options appear under make file or produce..)
*Set max bitrate to 17mbps, using avchd file, the 1min 23sec clip took 12min 36sec to “quick render” (no menu), cpu usage at 100% on the dual core 1.86ghz with vista x64 (this was about 10 minutes longer than Nero), the m2ts file could be added to dvd architect as well, *but no video could be seen in the preview, just a blank screen; file size 153mb, original 159mb, ***resultant file in powerdvd was a jittery pixilated mess compared to the original!
*Did the create disc option to AVCHD with menu, setting it to a folder on the harddrive rather than physical disc it took 16minutes on dual core 1.86ghz, resultant m2ts file was 153 mb in size compared to the original of 159mb, cpu usage was at 100% on the dual core 1.86ghz **same jittery pixilated mess as the direct to file option!
*Tried the BD 1920x1080 option, but smart rendering wasn’t possible here
*The HD mpeg2 1080i option allowed for smart rendering (mpeg2 file).. took about 6min 23 seconds to complete on the dual core 1.86ghz, file size was 206mb for the 1m 23 sec clip which was 159mb originally, (bit rate was set to a max variable of 25mbps), results: yet again, a jittery pixilated mess
Pixela ImageMixer 3 SE (came with canon):
**99 title import limit
**Program would lock up at random times, either browsing the "library" albums on the left hand side.. or by clicking on a video and clicking "Edit".. it would bring up the adding to library but hang.
**Fix was to remove the Klite Codec pack, in particular, the media splitter tool was causing the hang, however the solution to keep it installed is to Run the "Codec Tweak Tool" that is included with K-Lite, scroll down under "DirectShow Filter Management", check "MPEG TS splitter (Haali)", click Next and then Finish. This should disable Haali media splitter for m2ts files. (thanks spocko)
**Test re-render to m2ts file, took 55 seconds on the QUADcore 2.4ghz for the 1m 23 second clip, final file size is 159mb m2ts, original 159mb; final output looks identical to original; Then tested stitching together a few to total 2mins worth.. took 1m 58 sec on the quad core 2.4ghz; (meaning 1 hour per 1 hour of video to transcode only on QUAD core)
**same re-render test (1m 23s clip) on dual core 1.86ghz took 1m 20 seconds (less time than quad, perhaps due to raid5 array), should still be 1 hour per 1 hour on dual core with raid5 anyway;
**Was able to import m2ts into DVDArchitect 5.0, didnt require re-render;
**Couldnt import my panasonic camera's mpeg mov files (DO NOT import any videos other than the ones from the Canon camcorder, or it will hose the program)
Nero Vision 6.0.6 (with nero 9):
**Quickest program to re-render multiple clips for simple edits and combines!
**has the same 99 title import issue
Export to AVC, bluray video compat at def 22,000kbits/sec and smart encoding on (1m 23sec sample on i7 920 at 2.66ghz): 6 seconds!! (orig file 159mb, final 159mb), final copy looks very much like original! (this mp4 file can be imported into dvd arch without recompress, though audio has to be recompressed).
Combining multiple clips (1hr42min) on i7 2.66ghz, into avc bluray compat took 9min 42sec (compare to 36 minutes with pixela or 10 minutes with MM7)!
Exporting multiple clips (1hr42min) on i7 2.66ghz to bluray structure to get at the mts file took about 10 minutes too. (this MTS does work without video recompression in DVDa, though audio needs compressed)
Exporting to mpeg2 on i7 2.66ghz, the 1m 23 sec clip, took 1m 22secs (222mb vs 159orig)
**Trying to combine panasonic tz5 mov 1280x720p with canon shots and write to folder, ends up with a "burn" error.. and often crashes Nero, best to just use Sony Vegas 8.0 pro for that type.
DVDArchitect 5.0:
** Can select multiple m2ts files
**If using the mp4 from Sony Vegas, it wants to recode the whole video (the avc mainconcept is showing as not compliant for some reason, use SONY AVC only)
**if using original m2ts (renamed files), or any m2ts, no recode needed, even with menu's
**from what I can see this is very basic, menu’s only, with some fancy buttons you can add, no transitions or effects
**Do not let Architect reencode, rather, render as the correct format in a different program, it will be MUCH faster
**Burnt a movie to DVD 4.5GB with menu, Magnavox BD player had no trouble playing it, though the audio seemed to be shifted to only the front right speaker (showed dolby digital though)
**Attempt to browse to the stream folder from a Nero image (tried avchd and bluray types), choosing the mts file, it tells me that its not of the required type when I try to create a bluray disc
**Actually, it didnt like any of the pinnacle mts or m2ts files either.. only the originals off the camcorder (HF10) either mts or m2ts would work on the add media prompt.
**MOV related: could add the 2x53sec clip mpg file, rendered BD in 18min 38sec on quad core with 47% cpu avg use (translates into 18 hours for 2 hours of mov files) and on dual core took 35mins9secs (translates into 35hours for 2 hours of video ), example of why to use a diff. program to render first
