Originally Posted by
elifino
Have you tried to import with iMovie(which is fewer steps than the log-and-transfer of Final Cut)? You could then share the iMovie project with Final Cut. I've read that FC uses a different codec which is technically superior, and maybe this is why it's more complicated.
Yes I have, but I rather use the ProRes format rather than AIC....Well the thing is, the more clips that are on the card/Internal Flash the longer it takes FCP to load them in to the Log and Transfer window....
So I feel if I leave the card clean before shooting (dump all my video onto the external HD) It might save some time...But that scares me...
UPDATE: found this on a website...MAKES PERFECT SENSE!!!
Day 1: Ok. You get to your hotel end of Day 1. You're with the lady, so you don't want a lengthy log and transfer process to occur. Create a folder on your desktop called Day 1. Simply plug in camera, and the "CANON" disk mounts on your hard drive. Open it, and drag the 1st folder (it should say AVCHD) into a folder on a desktop. It may take 20-30 minutes to copy, no sweat. Tend to the lady. Afterwards, unmount drive, erase camera contents for next day's shoot, and charge that ghastly 1 hr battery (i bought 2x 2hr batteries from B&H).
Day 2: Repeat process. Camera contents dragged onto desktop folder "Day 2" no use for iMovie or FCP yet. Enjoy your vacation!
Day 3: Shoot, Dump, Go home. Tell lady you're going to make the best video ever!
Return to your sun-less lair. We're going to make "Disk Images" or dmg's of what we just shot. When these "disks" are mounted, FCP will "think" we have three HF10's mounted and allow us to view all three days simultaneously. We can log at will, not convert anything yet, and save our logging progress until next logging session!
Additional advantages: You can be shooting or charging the camera's battery while footage is safe & sound, ready to be logged and tranferred.
1) Open folder "Day 1." Get info on 1st AVCHD folder- note the SIZE of the data. Repeat for Day 2 & Day 3. We need to know the SIZE of the data. Let's pretend Day 1's size was 6.2 GB
2) Now, open up Disk Utility (applications > Utilities > Disk Utility).
Create a new disk image. When the dialogue pops up, offering you a 40 megabyte disk image, tell it you would like a "custom" size, and enter whatever Day 1's size was (6.2 GB, but actually, add about .1 GB for lame ghost data, please, so 6.3 GB). Also, name the disk image "Day 1." Depending on space, you may want to create the disk image on an external drive.
3) The disk image will take a few minutes to create itself. Once it is created, it will mount itself like a disk on your desktop. Now, open the "Day 1" folder on your desktop and it will reveal the AVCHD folder. Drag that onto your "Day 1" disk image (wait for copy). Launch FCP or iMovie, then the log & transfer to test. I had problems with getting the right AVCHD folder at the 1st level of the disk image. For the HF10, the folder hierarchy should follow: AVCHD > (then 3 folders) AVCHDTN, BDMV, and CANON. Sometimes there was an annoying AVCHD folder at the 1st level that had the real AVCHD folder I needed, so I just moved it around. It's not as hard as I probably just made it out to be. If it doesn't make sense, Read it twice, it's very easy I promise.
4) Repeat for Day 2, and Day 3. Remember: The folder hierarchy should go AVCHD > (3 Folders in here) AVCHDTN, BDMV, CANON. Drag Day 2's content into the Day 2 disk image, same for Day 3.
Now you should have 3 disk images (Day 1, Day 2, and Day 3).
When I launch FCP, then launch Log & Transfer, it recognizes all 3 disk images, and as a bonus, assigns the disk name to each clip's reel. So now if I log and transfer something from Day 1, it knows automatically it's from "Day 1."
You can now delete the footage off your desktop (but not the disk images you created!). If you unmount the disk images, just find the dmg you created earlier, double click, and mount right back up.
So in this vacation video of which we shot 3 days of material, we're going to be responsible and go through our Log & Transfer window and select and properly label ONLY the clips we want. Then we transfer. We just saved a lot of space by not transferring EVERYTHING! If we want to go back later and look for a shot we didn't think we need, mount up the disk images and return to find them. Keep the camera in the closet
Word of caution: Whether we have a camera hooked up or disk images, FCP crashes often when intensely viewing material in Log & Transfer. So after each clip we set in & out points for and label, SAVE ALL (or option/apple/s). If it crashes and comes back, It remembers our progress. I enjoy labeling, setting in and out points, and moving on, then mass transferring as I go to bed or leave for the market. Always creates a much more organized project this way too.
To me, this process made sense. I've done tape for years and enjoyed it. But I'm loving the hard drive process / experience. And creating these DMG's as ways to archive + log & transfer have really sealed the deal in terms of cost/convenience/time.
Hope this helps anyone out there with these cameras. The AVCHD format is new and wacky, but joyous! Good Luck!!!
