Originally Posted by Mike52
Hey Tom.
I just downloaded Corels' Videostudio Pro x3 (a trial version). I am concerned about rerendering which results in a lesser video quality. Back then, when producing an AVCHD DVD without transitions, etc., Corel put out a pretty good video, but when anything like transitions, etc. are added, the quality seemed to go down. How is the quality of your AVCHD video when you add transitions, titles, etc.? With Pinnacle, it rerenders things so badly that the resulting AVCHD DVD isn't much better than if I were to simply burn the AVCHD DVD as an SD disk. Nero does much better, but still not to the level I would like.
A year and a half ago, I tried Videostudio Pro x2 and thought the results were similar to Neros, but found that there were less tools to work with (at least that was my impression at the time), especially compared to Pinnacle 12s' suite of tools.
What is your opinion of the Pro x3 program? Especially compared to the x2 program? Does it render AVCHD video even better than x2 did, or is it about the same (even when adding transitions, etc. to it)? Is it easier working with AVCHD or about the same?
Thanks Tom.
Mike
Hey Tom.
Thanks Tom.
Mike
This problem has been around since VideoStudioX2. I highly recommend you download a 30 day trial of Neo 2 with booster. I've added all kinds of transitions and the output is stunning.
