In order to get good sound I need to put my front speakers roughly 3' out in the room- therefore my screenwall will hav a shadowboxof about 3' is that OK- I am going to use black 701 for the fronts and use fidelio black velvet for the shadow box- thanks
AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › How deep a shadow box can you build?
AVS Top Picks
