AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Denon 4308ci Owners Thread
The "Official" Denon 4308ci Owners Thread - Page 43
post #1261 of 5033
I bought a new DVR (panasonic EH67) and try connecting it using HDMI to my 4308 which connected to a sony projector VW60. I got no video signal at all.
It works if I connect my DVR to the projector directly using HDMI. It also works if I use s-video to connect to the 4308.
Can anyone help? Will the new firmware update helps? (but I cannot login to the firmware update site anyway)
Thanks for your help!!
post #1262 of 5033
What is the resolution of your display? How long is your HDMI cable? HDMI 1.3 has twice the bandwidth of earlier versions. Long lengths could cause problems.
post #1263 of 5033
Does the Denon show up on the projector at all (i.e. OSD, setup, etc.)
I assume the Denon is set to PAL output?
post #1264 of 5033
ok.. I'm starting to get someone overwhelmed by all of the surround sound settings :-)
I have a PS3 and this is regarding Dolby EX and DTS-ES playback.
I can't seem to figure out how to set my Denon up to automatically detect Dolby EX and DTS ES dvds. I've gone in and played with the AFDM (page 43 in manual) and SB CH Out. One set of settings will display DTS-ES discreet and others will show Dolby Digital EX..
I have PS3 set to bitstream via HDMI on a 6.1 speaker configuration. Is there one set of settings that will work for everything?
post #1265 of 5033
I run everything on my PS3 as Multichannel PCM not bitstream, so DD and DTS etc., show up on the Denon as Multi PCM. The PS3 converts everything to MPCM and the Denon sounds great.
post #1266 of 5033
Originally Posted by migs_inc View Post
Yes, it's a challenge. I learn a little more every week, and the main lessons have been these:
  1. If you want to change volume, input or the like, press "Amp" on the upper left of the touch screen first.
  2. For internet radio, if the touch screen controls are not working, press NET DTU again.
  3. TU selects regular AM/FM. (Yes, I know, sounds stupid, but I thought it read TV, not TU - duh!)
  4. And, of course, keep the manual handy
Have fun...
Thanks for your help - so far I am loving this Reciever
post #1267 of 5033
Hey people, I just got my 4308 on thursday and its a lot more technical then my old denon avr 3300. Did my updates via receiver been hard wired to the router and worked like a charm. The receiver works well with my network when its wired to the router. But I can't get it to connect wirelessly. The denon sees my network but I get the failed connection when I try to connect. I do have my password correct but I can't get it to connect!!! Could it be a compatibility issue with router and denon. I have a d-link dir-655 and it connected wirelessly with my xbox and ps3. Help!!!!!!!!!!!!!!!!!!!!!
post #1268 of 5033
I used the same HDMI cable that connects my PS3 (it works) but not with the Panasonic EH67. My DVR also works fine with my plasma TV via HDMI connection. It just does work with the 4308????? Why......sigh..
Please help.
post #1269 of 5033
Please help.
post #1270 of 5033
Please help.
Once again, is your entire chain PAL, or only the EH67?
post #1271 of 5033
dingus,
make sure you don't have any spaces in your ssid on your wireless router.
post #1272 of 5033
Originally Posted by vcor View Post
I've had an Onkyo 905 on order for about 3 months now and I'm starting to look closer at the 4308 - I'd likely jump if they were the same price (it has some specific features I like such as 7 video inputs vs 6 in the Onkyo, but no Reon). Very hard to choose which one as both are really nice, but a $400-500 savings for Onkyo is nothing to ignore. I don't like the Onkyo's OSD issues (affects color/black level).
I've actually read all the posts on both the 905 and 4308 forums and both manuals. To me most of the issues are mostly annoying from both camps, but not showstoppers considering all the rest of the package and the value they have.
Most issues have some kind of work-around and the hope that a firmware update will be available from both companies. It's very clear Denon has a update in the works (any day now?) with a beta available. No word from Onkyo if a firmware update is really going to be available, but lots of hopeful talk in the forum.
I've updated my comparison list now that the Denon manual is available if anyone else is still on the fence. I've also made it clearer about various features that seem to be confusing (2 hdmi outs, maximum usable video inputs, powered zone two, etc.).
http://www.theosfiles.com//zzz/recei...vs_4308CI.html
http://www.theosfiles.com/zzz/receiv...vs_3808CI.html
Great Comparison,
Couple of corrections:
1. There are 8 seating positions available with the AVR-4308 and AVR-3808 as previously mentioned, and
2. There is independent crossover control on the 4308, and the 3808. You find this under the crossover part of the menu under "Advanced"
3. Firmware update is currently available for 4308, and 3808.
post #1273 of 5033
Only the EH67 is Pal. I test by playing DVD with the EH67. I am sure it is the problem with the 4308 because I used the same HDMI 1.3 cable to connect my EH67 directly to the projector and it works.
I called Denon HK today and they said the have received a few complaints about 4308 not able to recognise some players (eg new Sony blueray, My panasonic EH67 etc)
They are talking to Denon Japan about the problem!!! In the mean time, I am stuck with using S-video for my new HD-DVR panasonic EH67!!! So frustrated!
Dear all, think twice before you buy 4308 with other new player. 4308 is so buggy!!!!
post #1274 of 5033
Thanks for all the help.
I have since worked out most of the kinks. Both Twonky and tversity work. The WLAN connection isn't the most stable (sometimes connection fails), but when it's there, all works.
post #1275 of 5033
Originally Posted by tsmalls3 View Post
Great Comparison,
Another thing I noticed: The Onkyo GUI is 480p(as far as I could tell ) & shuts off the video source when its used. The Denon GUI can go up to 1080p & displays over the video source when used.
post #1276 of 5033
It's taken me some time to learn the navigation of the GUI on the Denon. But I must say that having owned the Onkyo 875, that the Denon GUI smokes the Onkyo OSD. In fact, the Onkyo although a pretty nice receiver is barely memorable. Making changes with the Denon is speedy and none of the other issues I had with the Onkyo like speaker popping, excessive heat, and audio dropouts. Making changes to video and audio on the fly is a much desired feature of my Denon 4308CI receiver.
post #1277 of 5033
I am looking for the firmware update page for the 4308 to read more about it. I couldn't find anything on either Denon Canada or Denon USA websites. Would any of you point me to the right direction? Thanks.
post #1278 of 5033
Originally Posted by bfdtv View Post
Yes, when it comes to 1080i channels...
As others confirmed by tests earlier in this thread, the Denons downconvert 1920x1080i signals to 1920x540p when you select 1080p or 720p output. Some older displays do the same thing. With the Onkyo, you get full 1080p output, and 1080i->1080p->720p output when you select 720p. Depending on the size of your display and viewing distance, you may not notice a difference.
The SD up conversion on the Onkyo is a little better, but the SD upconversion on the Denon is still quite good.
Now, the Onkyo is far from perfect. Denons aren't the only receivers with bugs. Onkyo has a fair share of their own too, and they have not yet released a firmware update for the 875 or 905. For example, if you enable the OSD on the Onkyos (for on-screen volume control, etc), the box does YPrPb->RGB->YPrPb conversion which negatively affects color fidelity.
that doesn't make since to me, why would denon claim up converts to 1080p. if this is true, it should read upconverts to 540p, one would think this would be less than ideal if you have a 1080p tv, if thats true might as well let my tv deinterlace the 1080i signal from my HR20, why have the denon output it as 1920x540p just to have the tv scale it back up to 1920x1080p
post #1279 of 5033
Opps! On #1 I misread the manual that talks about you need at least 6 positions. Dam - had it right before at 8!
I've updated the charts with these corrections. Thanks!
post #1280 of 5033
Picked up the 4308CI over the weekend. I had the 3808CI, had some frustrations with it, returned it to search for something better on the market. After two weeks, I was back where I started - the Denon's are the most well-rounded A/V receivers on the market.
I am much happier with the 4308 over the 3808. Maybe I am just putting more effort into it than I was willing to with the 3808, but it seems to 'do what it is supposed to' the first time round. Audessy went well, HD stations are working, network recognition went well (I'll tackle Twonkey later to work with my Mac). Bi-amping worked, but no noticeable difference in sound. Overall, I'm pretty happy with it.
That being said, I have one unresolved issue. I can not get the sub to work with 'Stereo' mode. I had this issue on the 3808 and was able to manually increase the LFE channel. I have done the same on the 4308, but no increase in output. The setup and manual state 'stereo' is FL, FR and Sub. I've played with crossovers, 'LFE' vs. 'LFE+Main' settings, 'Large vs. Small', etc. No luck.
Anybody else have this issue? Any input is appreciated.
post #1281 of 5033
Does anyone know if the Denon servers are currently available? I've got my 4308 networked, but when I try and do the firmware upgrade, it just hangs on the "please wait"...
I have all other network connectivity working, its as if the Denon servers are not responding.
Does anyone know if there is a way to test this out? Anyone able to perform the on-line update in the last 48 hrs?
Marc
post #1282 of 5033
Has anyone tried to replace the WLAN antenna with a longer/stronger/better one to increase the connection stability?
I'm contemplating this, but I'm not sure that it would make a noticeable difference.
post #1283 of 5033
Marc
I ran into that and tried a little later and it worked fine - be prepared to wait for a solid 1-2 hours for the firmware to complete. I would recommend you do the update via Eithernet. I lot of people ran into problems here but I was fortunate and it worked from firmware 1 - 14 and even gave me the update complete message!
Good Luck!
post #1284 of 5033
I was on the phone yesterday with Denon about my 4308 skipping over updates 9,10 and 11. Rog at Denon said that they are still having issues with the server that is located in Japan and recommended that I try and perform the firmware update in about 7-10 days. He said by then they should have it up and running correctly. Also before doing the update you need to do a reset via turning of the power(the little on/off button) hold down the UP arrow and DOWN arrow inside the panel and then turn the receiver back on. At first everyone said to hold down the status and DSP button but I was told yesterday that the wrong info was put out by Denon on doing the reset before the firmware update.
post #1285 of 5033
This means I need to lose all my current settings (Audyssey setup, etc.) to perform the firmware update? I have not seen the release notes for it, but does this update seem to be worth the trouble of reconfiguring everything on the receciver?
The only issues I've had so far are - infrequently - losing the GUI when using streaming features (which is fixed by hitting the hard restart button). If a fix to that is the only benefit to expect, I would think it might not be worth having to reconfigure all receiver settings.
post #1286 of 5033
This is The major benefit of the FW update....and to me it was worth it. Since I wrote down much of the settings, it went quickly to restore the settings correctly. I did redo the Audyessy however.
post #1287 of 5033
I think the Denon 4308 also allows you to trim the volume level for each input - manual page 39, Input Mode setup, Source Level ("Corrects the playback level of the selected input source's audio input").
post #1288 of 5033
I have posted on another Denon AVR-3808CI thread, a couple of days ago, a serious problem I have with my 4308. Just before I make another attempt to get ANY help from Denon, I would appreciate any reality check data re HDMI transmissions.
My issue with the 4308 is that while it transmits video data flawlessly to a Panasonic 1080P projector over HDMI, and while it does so from three HDMI sources (cable, HD-DVD, and Blu Ray), as well as three component sources (component into the 4308, then converted and transmitted over the Denon HDMI output), it will accept NO composite or S-cable inputs - when such inputs are loaded, no video over the HDMI cable to the projector is evident.
After I spent over 45 hours on this issue since late last week, to no avail. It might be noted that I believe I have all the setting in the correct position. After successfully transmitting video over the HDMI output from a Component input, I "unassign" the component on that input selection and plug in an S-cable - then, there is no video signal. I contacted Denon support in New Jersey, and after extensive conversation with one of their reps (who was off line for a while puportedly talking with two "engineers" about the issue), and after I was led through an extensive intertogatory about the settings on my unit, as well as what I believe to be totally irrelavaent queries (such as, what specific devices, brands, model numbers I was trying to connect with composite or S-cable?), I was informed that my problem rested solely on my use of too long an HDMI transmission line (fifty seven feet) between my Denon receiver, and the projector. I pointed out that at no time had I ever had any evident "transmission" problems in this hook-up with the three HDMI inputs currently in use, or any component inputs, only composite and S. When I inquired as to what the HDMI cable length could possibly have to do with the faulty input welection situation I had, I was told - it has something to do with the deinterlacing in the projector - it is because the length of the HDMI cable doesn't leave you enough power to handle non-digital sources. Well, it didn't matter that I did not comprehend anything I was being told - that obviously some non-digital sources (composite) were being handled nicely - that the Blue Jeans / Belden HDMI cable had been certified to at least 70 foot runs - that there was nothing in my 55 years in audio, 25 years in design and installation of home theaters for my self and friends, my study of electrical engineering at Purdue, etc. that was coincident with what I was being autoritatively told by the Denon service person. I was told to get a 12 foot HDMI cable ("that's all they're good for - the certifications are phoney") and my problem would be solved - and with that I was dismissed. By the way, this Denon person has been earlier identified in this thread as "Rog" - in fact, when I inquired, he said, "spelled R A J".
Incidentally, one person on another thread justifiably asked the question, when I had posed this problem earlier, since the receiver was obviously defective, why didn't I just return it. Well, I can't. For the first 33 days I had the product, I only plugged in three HDMI connected inputs. I assumed that if the receiver would work with something as potentially as touchy as this kind of input, I would generally have no problem with other sources. It was only on the 34th day, after I had purchased a Velodyne SMS-1, and attempted to plug in its S-cable output that I discovered the problem.
I would suggest that what I and others here (and also as evidenced on the Onkyo and Yamaha and other products threads) have experienced is the widening acceptabliity of products with faulty microprocessors. How long will it be before we who purchase higher end receivers see the kind of failure rate that runs rampent with PCs.
If anyone has any insight as to how apparently perfect HDMI transmission out of a Denon reciever might be adversely effected by certain types of analog inputs, I would be thrilled to be enlightened and more accepting of the expertise of the Denon minions. Or if anyone has any suggestions as to how I might possibly have an incorrect set up, I would be deeply appreciative.
If I do not resolve this issue within the next seven days, I will be tearing my system apart, will be shipping the Denon to the authorized service center here in Austin, Texas, will be purchasing and installing a Yamaha RX-V3800, and will be selling the Denon at a nice reduced price, assuming that Denon can do anything as far as repair is concerned.
I had closed an earlier post by saying that this Denon product was the most defective anything I had ever experienced in the electronics field. I will close this one by saying that while not all of the other home theater products I have are absolutely perfect, I will say without exception that they are fully reliable and that they validly perform the functions they were purported to perform - this includes amoung others, products by Sony, Toshiba, Yamaha, Pioneer, Panasonic, Velodyne, Hsu, Allison, Boston Acoustics, Silicone Image, Dual, Teac, Nakamichi, dbx, Ampex, Shure, Electrovoice, Koss, Zoom, Felston, Logitech, RCA, and may I dare say it (!) Radio Shack. But not Denon.
post #1289 of 5033
so your issue is no S or composite over HDMI?
If you have a component video connection and S video connection to the same input, I would try unplugging the component video completely, not just un-assigning it.
Also make sure A to H is enabled in your system setup, with the HDMI output set to a resolution your display recognizes.
Lastly have you tried a microprocessor reset?
Cheers...
post #1290 of 5033
Dear Dartpaul:
Thanks so much for your thoughts re my junk Denon! I indicated the 45 hours I had spent trying to resolve this issue - now I've spent (today) another four hours - I have now found a way to resolve my Denon problem, noted at the end of this post.
But specifically, in response to each of your kind and attentive thoughts: 1) "so your issue is no S or composite over HDMI? If you have a component video connection and S video connection to the same input, I would try unplugging the component video completely, not just un-assigning it." - I have, at one time or another, siconnecte ALL component cables (from any component input), and disconnected all HDMI input cables, and triple checked to assure that NO HDMI input and NO component input was assigned to anything. I then tested almost all the S and composite inputs, one at a time - on some of these tests I plugged in the right and left analog audio inputs to assure that the input selector was appropriate - and audio was output over speakers, but no video was output to the projector over HDMI.
2) "Also make sure A to H is enabled in your system setup, with the HDMI output set to a resolution your display recognizes." I have enabled "A to H" and later "A to H & H to H" - and with various ouput resolutions - no video arrived at projector.
3) "Lastly have you tried a microprocessor reset?" Yes, I reset the microprocessor 7 (SEVEN) times! The first time I did this, I was then able to transmit S input - I was thrilled! I spent quite a bit of time resetting EVERYTHING, and then the S input did not work. So, over a period of days, I reset 6 more times - i did not matter, no composite or S transmission, although all HDMI and component contiued to work fine. BTW, the Denon Raj minion discounted that I had inexplicably been able to get a S input transmission to work once - and he just kept insisting that my HDMI cable was too long.
4) I have attempted dozens of other settings (I guess the various combinations and pemutations add up to thousands - I tried to keep track for a while, by charting, but gave up).
But I have now almost solved my Denon problem entirely. Since my last post, I decided not to wait another seven days, I just ordered a Yamaha RX-V3800 Receiver, on backorder, which should be delivered by November 10. My hope is that Yamaha will have the latest download for its microprocessors, and have some of the 3800's current bugs worked out somewhat (see posts on AVS re this Yamaha). If so, I will attempt to get Denon to repair my 4308 - if they do, I will sell it at a considerable discount. If they do not, I will pour gasoline over the Denon, and video the resulting conflragation, and post the video all over the Internet. Then my Denon problem will be resolved.
In the meantime, if anyone else has any kind alternative suggestions about resolution short of total destruction, I would welcome them.
Cheers to you all
J. William, Director of Bee Cave Digital Video, Inc.,
aka Sonyuser
