AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Denon 4308ci Owners Thread
The "Official" Denon 4308ci Owners Thread - Page 7
post #181 of 5033
Originally Posted by DVRDude View Post
Arrrgh...Cockpit Error!!! Internet Radio works great on the 4308ci. The reason that I could not get it working before is that I missed a digit when I put in my router IP in the receiver.
Once the initial connection is completed, a list of genre/stations is available in the GUI. You then go to the radiodenon.com site and login with your receiver's MAC address. From there you can create your own groups that will appear under your favorites. You then add stations to your favorites from the list. It looks like about 1800 stations are available. As you update your station choices on radiodenon.com, it pushes the changes to the 4308. I added a few 128Kb streams to my favorites, and they sound fantastic on the receiver.
Thank you DVRDude. I really want to get this working so I am only going to work on this tomorrow. This is one of the main resons why I bought the 4308. Has anyone tried PIP yet and does it work. If you only have 1 HDMI cable going to your TV then can you have say a DVD and the TV playing at the same time or would you need to run 2 HDMI ports to the TV for this?
post #182 of 5033
Originally Posted by erikk View Post
have you tried doing anything else? Streaming from your computer? Etc? Because there's probably no firmware update on the denon server (if the server is even set up at all yet) and depending on how the receiver has been set up by denon the error messages may not be very explanatory.
Thanks Eric, you are right I need to focus on something like streaming rather than looking for new firmware on the denon site.
post #183 of 5033
Originally Posted by CARRAM View Post
If anybody has the time would they mind posting the size of the box. Need to work out if it will fit in my car.
Many thanks
Ron
The box is about 21" square x 14" Tall
post #184 of 5033
I don't know of a way to select two video sources to play through the same output connection. If you find a way, that would be a good feature. Otherwise, you would have to run two connections to the TV like you mentioned. I haven't played with the second HDMI output at all yet. I pretty much have everything dialed-in now, so I guess I will experiment with the extra outputs.
post #185 of 5033
PIP is a function/option of a TV, not a AVR.
post #186 of 5033
I've only begun to scratch the surface with the 4308 so far...and because of the gf in the other room, I haven't even taken her for a real drive. I have been setting up all my video sources and everything appears to be upscaling to 1080P and pass-throughing okay. I have my cable box hooked up through it at as well, but I am a little dissapointed with delays when changing channels. It can take up to 10 seconds to display a channel if I go from an HD channel to a non-HD channel. Is this normal? Outside of that, so far so good and I will report back more findings later on today!
post #187 of 5033
But the PIP needs to be sent data from the AVR? The question is can the AVR send 2 data streams at a time through 1 HDMI cable or does it need to have a 2nd HDMI cable plugged into the TV?
post #188 of 5033
So is video scaling and color manipulation. More and more video work is being done in the receiver and since receivers are trying their best to make sure there's only one cable going to the TV this is definitely a feature that makes sense for them to offer. It may not be something that the Denon does now but I guarantee that we'll see an AVR that does this in either the next generation of receivers or the one after that at worst.
post #189 of 5033
Hey Denonlover,
Any luck with your wireless connection? It still doesn't work for me.
When I search for a connection, it identifies my wireless connection and asks me to enter my WEP. But when I enter the correct WEP, it doesn't connect and i keep getting a connection failed message.
Argh.
post #190 of 5033
You are I are having the same exact problem JBRhee. I am pretty good at networking but I asked my buddy (Network Guru at Experian) to come by and he also could not seem to get it up and running? We tried setting it up in every possible combination? I even took down my WPA and tried a WEP just in case that might have been the problem. This thing will nto log in no matter what.
post #191 of 5033
Damn. I'll try calling them tonight if i get home early enough. If i get it to work, i'll let you know.
Btw, what do guys have your HDMI video settings set to? A to H or A to H & H to H? And, what's the difference?
post #192 of 5033
Just a quick question:
Is the 4308 able to overlay onscreen information like volume settings on incoming hdmi signals (output hdmi as well)?
The manual doesn´t mention that it´s not working with hdmi sources (unlike the manuals of the older models).
Stefan
post #193 of 5033
Does anyone have the phone number for technical help at Denon handy?
post #194 of 5033
I have a quick question regarding the wifi encryption options. I read that people have been trying to get WEP as well as WPA to work. I was wondering if WPA2 was also supported.
(Sorry if this has been answered before.)
TIA!
____
Axel
post #195 of 5033
[quote=boysmile]Just a quick question:
Could someone please answer this, I would like to know as well.
post #196 of 5033
[quote=muncey]
Yes, you see on screen unfo for things such as volume.
post #197 of 5033
By the way, here are the telephone numbers if you need to call if you r are in North America.
CONTACT US
Thank you for visiting the Denon Electronics (USA) website. If you have specific questions about our products, their operation, or any other inquiries, we invite you to contact us by telephone, fax, or by mail as shown below:
Denon Electronics (USA) LLC is corporately headquartered in Mahwah, New Jersey:
Ship To:
D&M Service Repair
Attn: Denon Customer Service
100 Corporate Drive
Mahwah, NJ 07430-2041
General Office hours of operation:
8:30 AM to 5:30 PM ET, M-F
Tel:
201-762-6500 (Main Office)
Fax:
201-762-6670 (Main Fax)
Phone support is listed as follows:
Customer Service hours of operation:
9:00 AM to 5:00 PM ET, M-F
Tel:
800-497-8921
201-762-6665
Fax:
201-762-6695
Tech and Operational Support hours of operation:
Tel:
800-497-8921
201-762-6665
Fax:
201-762-6695
Repair and Service hours of operation:
Tel:
800-497-8921
201-762-6665
Fax:
888-544-8434
201-762-6686
eFax:
973-215-2887 (Repair Status Only)
post #198 of 5033
Can anyone confirm if WMA Lossless is supported? I think this was asked earlier, but I never saw a response.
post #199 of 5033
Perhaps this will help? Page 53 of the manual:
Always happy to help a "clark"
post #200 of 5033
How good is HD radio compared to regular FM? Also does HD radio usually require a stronger signal than say what you get with a regular FM antenna that comes with? Is HD radio simular to OTA HD tv; with OTA tv you either get a picture or nothing, no in between.
post #201 of 5033
CONTACT US
Ship To:
D&M Service Repair
100 Corporate Drive
Tel:
Fax:
Tel:
800-497-8921
201-762-6665
Fax:
201-762-6695
Tel:
800-497-8921
201-762-6665
Fax:
201-762-6695
Tel:
800-497-8921
201-762-6665
Fax:
888-544-8434
201-762-6686
eFax:
All eastern time? I'll never get this fixed.
post #202 of 5033
I have heard that the clarity is much better, though I will never get to test it out since I live in an area where regular fm doesn't even work well.
post #203 of 5033
Yep, us Clarks have to stick together
Thanks for the link.
So if I am reading this correctly, looks like it does *NOT* support it. Looks like I will have to go with FLAC. Man do I have some work ahead of me!
post #204 of 5033
RJ-45 Ethernet Port Third Party Controllers, PC Audio Streaming,
Internet Radio and Web Browser Function Enhanced for WMA
Loseless/
AAC/jpeg Photos, Internet Radio now MP3 and WMA support
There is the above quote from some preliminary lit from back in 2/07.... see attachment pdf.
Right click and new tab.......
Denons.pdf 68.69140625k . file
post #205 of 5033
My 4308 has arrived in the store. I won't have it in my hands until next Tuesday! We're in the process of moving to the new house so I can't touch it until then. Figured I be better off not picking it up until I can play with it and make sure it wasn't DOA.
Its killing me................
Mike
post #206 of 5033
I live in SoCal, so we should have a decent selection of HD Radio stations. With the included loop(AM) and wire(FM) HD antennas, I can hardly get any reception for HD radio. I had been working on setting up other aspects of the receiver, so I have not checked on HD radio since last Friday. I will play a bit more with it tonight and post my results.
post #207 of 5033
Could someone confirm that following scenario would work on 4308...
Main zone 5.1 input HDMI ( watching DVD movie) - no bi-amp
Zone 2 - 2 patio speakers (streaming content from net)
Would I be able to do this and have both things running at the same?
Thx
post #208 of 5033
Hi DVRDude
I live in Chino and work in Orange (Katella & the 57). When I'm driving to and from work I lose most radio stations going through South Diamond Bar/Fullerton. I think it is because of those tall hills North of Lambert.
post #209 of 5033
RJ-45 Ethernet Port - Third Party Controllers, PC Audio Streaming,
Internet Radio and Web Browser Function- Enhanced for WMA
Loseless/
This is fantastic! Now if I can just get my hands on one of these things... I pre-orderd through J&R and I think they are the last place on earth to get stock!
post #210 of 5033
Current 4308 owners - cazzy raises an issue worth feedback from all of you. The recently released Onkyo 875 seems to a delay when changing channels that many owners consider intolerable (3-4 seconds). The delay is the worst when the STB is allowed to pass through at native resolution requiring the AVR to do the scaling and possibly de-interlacing.
All of us can understand some delays as the AVR syncs and begins processing the signal but 4 second delays are a tough WAF factor (trying to be practical here guys) and anything such as a 10 second delay is unacceptable.
I know many of us sit on the Onkyo/Denon fence and implementation of the technology will be the key issue for many including me. If VP is not done well in the AVR, than we will simply have to deal with it outside.
Sorry for the ramble but this is important to me.....
