You seemed to be quite versed in the differences in sound quality of each generation of this piece
Can I ask ....have you owned all of these..demoed all of them
what differences are there?
And what does the next level in sound mean to you..ie...do you have any specifics about the material you were listening to in the demo and what differences there were in the piece that you could discern that made it on another level
What would I expect to hear , different, going from a 885 to a 5508
You had said earlier that you thought the reference pieces were only 2-3% better than these Onkyo's..as I recall you said 97-98% of the quality for 20% of the price?
That being said...if the 5508 is on another level...where is its percentage fall in regard to the 885?
You also said the Anthem was on another level....and I handily agree with that
But based on the percentages..of 97-98%...that's not another level...to me anyway... and not really a reason to upgrade..unless of course it was $100 or something
My ears don't come anywhere close to the percentages you assigned...but we all have different ears so I get that
To give you an example of some source material I use for a litmus test
For example...if I am doing a video demo a couple of blu rays I use
The Dark Knight....the opening 2 chapers with the bank robbery and the skyview of the buildings
Avatar...again like chapters 3-4 with the fly over scene and the scene where there is an issue with the aggressive animal
Avatar is also a good one for home theater testing....those same scenes I would listen to at reference levels and listen for dialogue clarity and any harshness or lack of
For music
Joe Sample...Sample This
A lot of keyboard work here as well as some female vocals done by Dianne Reeves
Lee Ritenaur..Color Rit
A lot of guitar work here as well as some vocals by Phil Perry
I could go on and on with demo discs
But anyway...the music portion is where the Onkyo falls short and where I actually went backwards from what I owned before
Amazingly..or perhaps not..the local Anthem/Integra,Rotel, Levinson, Bryston..etc dealer just happened to have of this material ( except for one CD) in house that they used for demos
So for me..if I know the source material very well..."As best I can" I can compare what I have and its sound quality to the quality in the demo room
Again...how much different would it sound in my room...that's the unknown
But I can't imagine that an acoustically done demo room to my home theater environment can turn a silk purse into a sow's ear
Warren
, I've heard great things about the 4310, which originally piqued my interest, and then the 4810.
I do want to try the UPS-5 and for home theater is should have more than enough juice.
