under the basic information screen for the 2500 it states
"Native bit stream output for Dolby Digital+, Dolby TrueHD, and dts-HD master audio"
on another note, my sony PS3 loads discs what seems like almost instantaneously, maybe it starts loading them while i'm in the PS3 home screen, but as soon as i hit Blu ray, it goes right to the disk.
how does the Denon players compare to that?
also, how would the picture quality of the denon compare to the ps3, so far, i've seen so many blu ray player reviews that say the PQ of all the players is generally the same since the source is so good regardless.
if the 2500 doesn't have a realta for maybe noise reduction or what not, then you're jsut sending the plain ole blu ray signal from the disk to the display, same as my ps3 i'd assume.
is the $1,000 really worth it if i have no load time problems now, assumed negligable PQ increase, and JUST the capability to extract DTS-HD MA?
using uncompressed sound tracks right now sounds pretty damn fine to me through my denon 4308. AND, my ps3 is future upgradable to blue ray 2.0
I just don't see the appeal of these new players from denon, especially since there's no SACD and dvd-audio, not for the price they're asking for.
until there's a final spec 2.0 player that does everything and has better upscaling than my pioneer elite pro-150, i see no reason to replace my PS3 / denon 3910 combo
for the price of a PS3, i don't think you can ask for much more right now.
I'd like to see some screen shot comparisons between PS3 and the new denon's, just for proof's sake, then i'll start believing.
