Originally Posted by Woodshed
There is no "bitstream" option that would be the simplest way to set the player. The choices seem a bit more annoying and arent completely obvious with their end result.
Upon choosing DTS HDMA on Cast Away and playing the movie, the 5308 was NOT showing that it was receiving DTS HDMA. I think the person who "set up" the 5308 didn't set the inputs correctly, so I will try to get back and try SD DVD and set the 5308 correctly today.
If you are hearing audio on the 5308, then the input is correctly set to Auto or HDMI... I haven't yet found a way to get the HD-MA bitstream to decode the Core when the stream is coming over HDMI.
Is the 2500 set for "BD Audio Mode = HD Audio Output" and "HDMI Audio Out = HDMI Multi (Normal)" on the Audio Function setup page?
Hopefully it'll all be figured out before I get my unit
