Does that mean that there is a non HT specific lens that does the same job without the HT specific markup or does generic just mean not ISCO?
Originally Posted by Aussie Bob
About 0.4 inches (i.e. virtually none)
I modelled your set-up - ISCO, throw, screen-width - in my Zemax (professional optics) software and got this result.
I also have a spreadsheet that, instead of working things out iteratively with optical ray tracing like Zemax does, does the same thing using basic geometry and simple optics... and comes out with practically identical results (<.5% different) without needing to invest $000s in Zemax.
The spreadsheet works out the pincushion without a curved screen to +/- 0.5mm, and then from that curves the screen until the pincushion is <0.1mm .
Results are:
*** Pincushion (as I said) = 0.4 inches.
*** Your screen curvature to eliminate pincushion has a radius = 72.1 feet,
*** The dip in the middle = 4 inches
(or alternatively, you pull the edges of the screen 4 inches out from the wall towards the projector).
I know no-one's going to believe me, but comparing ISCOs by analysing published performance against other generic cylindrical lenses there seems to be little difference in pincushion performance.
Results are:
I also would find it hard to believe there are any patents still valid on basic cylindrical designs although Schneider has some relatively new IP on some of their modifications.
