Originally Posted by mykee50
I've had my 905 since 07'. I've never had a problem with it. I use it almost exclusively for TV and movies but sometimes for music. About a year ago I started getting a loud buzzer type of noise (no music) when on "Tuner". It happens on all zones.
Has anybody ever heard of this. Is it worth contacting Onkyo at this point?
"Buzzing in Seattle", Mike
I think you are probably hearing exactly what I described like a relay clicking. It clicks in high pace - like a buzzer if you like.
http://www.avsforum.com/avs-vb/showt...3#post20557963
My 905 is probably from the same period as yours, so presumably this is the next 'common' issue with theese units.
The thoughs seams to be that it is the hdmi input board that is in need of some TLC.
On my 905 it gets worse - it started with the input from the iptv box, and now I also have it on the Dune media player input, so I need to take action soon.
If I find the time, I might do a visual inspection this week-end, looking for very bad capacitors and so on. Don't think I'll have any time to do serious fault finding though.
I love it when I expect to have to jump through hoops and bend over backwards, then it turns out to be easy peasy
