AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Epik Subwoofer Thread
Official Epik Subwoofer Thread - Page 383
post #11461 of 19461
Originally Posted by JimP View Post
Running sweeps is no indication of a sub's power.
noted.
Robobob- thanks for your clarification and nice response. So many people throw doubts out there and question design aspects. The sub-woofer performs admirably in my specific setting. I would not hesitate to offer my sincere recommendation.
post #11462 of 19461
@robobob
I don't disagree, that is why I capped MAY. I will be running audyssey tonight prepping for tomorrow. Having to turn up the gain so much to keep up with the little tiny itty bitty JL 12" had me wondering.
On a side note, I would have no problem setting a cold beverage on the Empire at max volume. The JL, however, would make a big mess. It shakes like a wet dog at high volumes.
post #11463 of 19461
^^ I agree.....the cabinet has virtually no resonance when played at excruciating loud levels.
post #11464 of 19461
Originally Posted by RatVanMike View Post
My budget has increased from 2000 to almost 4000 and was looking at other options. The more I think about my options I think I am going to go with the Dual Empires. There is no doubt in my mine they will out perform the velodyne ct-150 I have now. With the money I will be saving I will upgrade HT system in the bedroom. The bedroom will get the old velodyne. Right now the bedroom has a 32" lcd and a cheap HT in a box. Looking to move the 32" and the HT in a box to the daycare room. I will be going with a 45"-55" plasma and Polk Audio Tsi series speakers. My wife is all excited cause she will be able to compete now, LOL only if she knew.....
Although the Empires sound like they would be fantastic, they are not the be-all end-all of subs, and Epik's not the only company on the block, especially if you have a lot more money to throw around. I doubt you want to "spend it all in one place" but $4K would get you Quad ULS-15s (or even 2 or 3 of them). They're sealed and arguably could offer better sound quality for music and clarity (based on HSU's reputation, not actual comparisons). It would also let you get a JL Fathom F113 with some change left over for room treatments/bass traps, maybe an eq if you need one.
Just a thought.
post #11465 of 19461
RatVan - if your budget is as you mentioned, you owe it to yourself to look at some other options as well - dual SUBM's would be hard to beat
post #11466 of 19461
Originally Posted by GuidingTheShaft View Post
@robobob
I don't disagree, that is why I capped MAY. I will be running audyssey tonight preping for tomorrow. Having to turn up the gain so much to keep up with the little tiny ity bitty JL 12" had me wondering.
On a side note. I would have no problem setting a cold beverage on the Empire at max volume. The JL however, would make a big mess. It shakes like wet dog at high volumes.
Understood. I was quoting for context, nothing personal!
I found and many report that the gain control (which gets confused with a volume control) of the Epik amplifier's typically is set higher than on other subs.
The gain control knob is to set the relative sensitivity of the sub's amplifier to the signal begin fed to it and is not directly related to its total power or headroom.
All this means is that, relative to other on-board sub amps, the gain control (input attenuator) has a different curve or range.
In fact, there is a bit of marketing in the choice of the setting curve of gain control knobs, with the subtle implication that if you have the gain control set at 9 o'clock out of a possible 3 or 4 o'clock max, that there is that much more "gas in the tank", that the amp is only "coasting along" when in fact, the gain is really maxed out at the 12 o'clock setting anyway!
In the Epik case, the gain control range is simply more realistic.
For maximum dynamic range without clipping, the consensus among Epik owners seems to be to set the sub's gain control such that you can set the prepro's LFE output to -3dB up to 0 but no higher, which ended up being somewhere between 11 and 12:30 on the previous models.
You may know this already but I repeat it for the benefit of any new lurkers.
post #11467 of 19461
Just a thought.
Well, that solution is 4 times more costly, I would hope it's an improvement.
The real question, which seems to be answered with increasing regularity with the continued user reviews, is the Epik Empire the biggest bang for the buck? It seems to be a resounding yes overall.
post #11468 of 19461
Chad also said you can place two of them side by side. I was surprised.
post #11469 of 19461
Originally Posted by robobob View Post
...snip...
Real music requires more from the amplifier's power supply, no doubt, but the amp running out of steam causes audible distortion or less than satisfying power levels, neither of which have yet been reported here.
...snip...
You answered your own question.
post #11470 of 19461
Originally Posted by mrbass21 View Post
Do they deliver on Saturday? I live in Denton, Tx and my package was delivered to Dallas Thursday. I took Friday off of work cause I figured it would be delivered then.... nope. It's sitting at "Scanned" on the shipment tracking.
Do they call to set up a delivery every time, cause I haven't received a phone call yet. I'm dying waiting for this sub!
Thats why I decided to pick mines up. For Two days after it had reached it's final destination before reaching me, it's status said "scanned". They scanned once each day, so I assume that meant it moved "up the line" for delivery. I just could not wait any longer and picked it up myself. I suggest bring someone to help you load if off at home. The ppl at DBS in Ft. Lauderdale were very nice a help me load it in my RAV. Unloading from garage to inhome however was quite.......sweaty .
post #11471 of 19461
I would wait until the Empire has settled in a while if you notice when ever a new sub hits its the best thing since sliced bread but once the smoke clears and the owners have settled down and the excitement of a new sub mellows out you'll start getting some more down to earth reviews , not to say the empire isnt a good sub .
post #11472 of 19461
By then the intro price might be over.
post #11473 of 19461
That's the point. He has a lot more money to spend now, so there's reason to not at least consider some higher-end options. I'm not slighting Epik or the Empire, or doubting that the Empire's got great bang for the buck (even when it settles into what will probably be a $1K price point). But he said he's got $4K to spend now... And as The Factor said, the dust hasn't settled yet, so there's still a lot of excitement without much objectivity and measument.
post #11474 of 19461
This is true and not to sound like a hypocrite because I have about the same patience as a starving GRIZZLY BEAR COMING OUT OF HIBERNATION, but im just saying ....
post #11475 of 19461
I was actually adding information lacking in your terse assertion: "Running sweeps is no indication of a sub's power."
The adequacy of the amp's P/S or reserve current has more to do with headroom than the average SPL attainable from real music versus slow sine sweeps as the source signal. If the sub amp can supply RMS current for a slow sine sweep through the driver's range creating an SPL curve, what remains open to question is only the headroom available for peaks, a much more qualified assertion.
My implied question was: "What value to anyone here was your statement without qualification or alternative, other than to pose as an authority?"
Since you are trying to be helpful, what methodology do you recommend for measuring sub power instead of slow sine sweeps? MLS sweeps?
post #11476 of 19461
Originally Posted by thirdeye11 View Post
I love how everyone is questioning the business methods here. "Why does Chad keep changing the product line?!" I'll tell you at least one of the reasons. He increases his customer base or target audience even further. DoingOK is proof positive of that. If Chad hadn't come out with 2 new lines, would DoingOK have bought 3 more subs from the existing (first gen) lineup? Chad just extended his product offering back to his existing customers by offering something bigger, better, and more impactful. I for one applaud his business sense, by continuing to push the envelope. As a business owner I would hope to always continue to improve my product offering as often as possible. It may be a new ID way of thinking (as opposed to the very consistent SVS who releases new products sparsely) but I see others who could benefit from these methods.
Introducing a new sub is perfectly understandable.
What seems odd, is to completely discontinue a successful line that compliments the new product, while filling a different niche.
Last year, when the old lines were eliminated, new models were introduced that were roughly comparable. If I remember correctly, there were some supply issues with some of the components, along with some other reasons for doing this. At the same time, some new products with 18" drivers were introduced. That made perfect sense, especially since we were told that the 18" drivers could do some things that the other subs couldn't, just due to their physical size. Quite a few of us jumped on these, and have been very pleased. I'm in this category. Just to be clear, the Phoenix is an amazing sub.
That brings us to the present. The amps have remained the same, so there doesn't seem to be a supply issue there. Maybe there's a reason for discontinuing the 18" line. There haven't been many (if any) reports of driver failures, so that doesn't seem to be the problem. They seemed to be selling well (there was no special sale on them at the end of last year, like there were with the 12" models). And almost all of the buyers seemed to be extremely pleased with them.
So, why discontinue all of them after less than a year? I can see eliminating the 12" in favor of the Empire, but the 18" would seem to offer a clearly different choice.
Again, it's Chad's business. Only he knows the sales numbers. He doesn't need to offer any explanation. But it does seem odd.
As an example, here's the kind of conversation these decisions produce:
"I bought a really fantastic 18" subwoofer last year."
"Which one?
"It's called a Phoenix, and it's made by Epik subs. It puts out some really powerful and impressive bass, and sounds fantastic in my room."
"Wow, sounds awesome. Where can I get one?"
"Well, uh, it's discontinued. They only sold them for about a year, and aren't making it, or any 18" subs anymore."
"Hmmm, must be really great, then. "
Again, I think the Phoenix is a truly fantastic sub and have no regrets in buying it. At the same time, it looks like Epik subs are designed as limited-edition, one-year runs, with little continuity or product line stability. There's nothing wrong with that, but it seems weird to constantly reinvent your entire offerings, rather than just work on continuously improving what you have while introducing some new products along the way.
One thing that doesn't seem to change is that Epik provides great products at outstanding prices. And that's the most important thing.
Scott
post #11477 of 19461
Originally Posted by DoingOK View Post
Aw, c'mon man, you could have squeezed a dragon in there! Definitely an empire though it wasn't out yet. Probably even a phoenix! Conquest maybe.....? Hell bash the wall in and stick dual A7-900s in there just cause you can.
post #11478 of 19461
Just a thought.
Careful, you will get flamed if you don't wholeheartedly praise the end all be all grand Empire. All other subs have their defecits....
post #11479 of 19461
I'd need to borrow a friends truck or something... I somehow doubt it will fit in a honda civic.
post #11480 of 19461
LMAO
"Which one?
Scott
Very well said and a very good point of view from a Epic owner.
post #11481 of 19461
Pretty sure that was his wife/fiancee's office setup...
I don't know about you, but I want a better setup than my wife!
post #11482 of 19461
Like I said in my post I have been considering more options. But the more I think about it there isnt much that will touch Dual Empires for the price. With the extra budget I will have the extra for atleast a 50" plasma and speakers for the bedroom and then some. Lets see spend it all on subs or get Empires and set up the bedroom also.
post #11483 of 19461
This is the business model:
Produce cheaper; less costly smaller subs and produce the mindset that you need two of these smaller subs to produce spectacular results....now Epik is selling two subs where one ordinarily would work. Cheaper, smaller, less power but TWO, now there you're talking. Actually its a brilliant plan and most will go for it. Got to love that plan!
post #11484 of 19461
Got to love ventroloquism from the nether region without lips moving, devoid of useful information, integrity or facts.
Troll much?
post #11485 of 19461
Just a thought.
I gather from your posts that anything that is the most expensive is supposedly the best. Didn't the posted said he intends to spend the exta money to upgrade his bedroom?
post #11486 of 19461
Right, so a single sub will be of no use to anybody, gotcha'.
post #11487 of 19461
I think it would be cheaper to manufacture one large subwoofer than two smaller subwoofers at a similar price. An extra sheet of MDF for a large sub is much cheaper than the extra sheet of MDF, an extra driver, and an extra amp required to make the second small sub. Not to mention I think it would require more time to build two smaller subs than one larger sub.
post #11488 of 19461
...now Epik is selling two subs where one ordinarily would work...
trust me...one is *plenty* in my 3300ft^3.
post #11489 of 19461
Yeah, now that you've heard the Empire you can see how it obviously.... oh....wait...
post #11490 of 19461
For over 2 years Epik built various models of various flavors of excellent subs. Most only bought one at a time throughout the menu. Some sold better than others, but all represented a huge effort in building different boxes...most of which Chad built himself. It's obvious that he rethought his line twice with the similar formulas. The 2nd rev greatly reduced cabinet size without compromising output. The third time his object is to build a winner, smaller footprint, able to compete with all his previous models in sound quality and output, sell alot of subs at a very attractive pricepoint, with a greatly reduced construction effort...then decide what to add on. His Empire is going to be his bread and butter sub...it already is. If you bought a previous rev, you still got a great sub, so what's to complain about. The fact that he's decided to no longer build them doesn't lessen their value. It just makes alot of sense for Epik to do what they are doing, especially in this economy. I'd take a very hard look at this sub as a single or as duals.
