AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Epik Subwoofer Thread
Official Epik Subwoofer Thread - Page 408
post #12211 of 19461
Originally Posted by eantala View Post
Sometimes I really hate life. I got Dual Emires coming in , Db Schenker called to say they're delivering tmw, I say ok is evening available this way I dont have to take a day off. They say no I say fine and notify my employer Im taking off, then they call back saying if the snow is bad they wont deliver and try again next week. I got po'd and said let me just pick the thing up. So now I got to drive home tonight in the snow, swap out my sedan for my minivan and head over to Newark,NJ by 7pm before they close. There's a chance I might not make it by then due to the snow.
Man the bass on these 2 empires better be worth it !!
I believe DB uses semis to deliver packages. I know they are heavy, but I wouldn't want a semi out on the roads near me during a snowstorm!
post #12212 of 19461
Good luck, i hope u get it and be careful on road.
post #12213 of 19461
Dude, I know you're all psyched but you paid $240 for shipping. Let them deliver it. That pallet is HEAVY lol. I love my Epiks but if you slide off the road getting them, the speakers won't be the only pair you're picking up ...
post #12214 of 19461
Wow that's Dedication!!! From what i've read and scene on this forum your really going to enjoy your new Empires!!! Be Careful and just remember theres always another day. So be careful and I hope you make it there safe and on time . BTW I would of done the same thing and as a matter of fact I have
post #12215 of 19461
Mine arrived 10 minutes before I had to go to work...It sat in St. Louis for 4 days before they decided to throw it on a truck and take it over here, but I have it now and I'll get to hook it up tomorrow!!!
post #12216 of 19461
My Empire was sent out on Tuesday and I picked it up today, It was heavy but I was able to lift it off my tailgate onto the ground just fine by myself.
I have had a bit of a time setting it up, (Still not done) If I use the LFE rca it sounds boomy not tight at all my avr is set at 80hz and dont like it.
If I use the crossover rca it sounds way better but the output is lower and I have to turn the gain higher used this way sounds real good but like I said its not all tuned in yet and still dinkin with placement.
post #12217 of 19461
The LFE input plays the full signal it's receiving. The crossover input filters out bass based on where your dial is set. That's why the volume is lower. Real LFE on a 5.1 soundtrack goes up to 120Hz, so you lose a lot of bass if you filter bass at the sub.
If it sounds boomy, you need to move the sub and/or your listening position. Make sure your seat is away from the wall, and move the sub out of the corner 2-3 feet or about 1/3 of the wall's length for starters. The boominess comes from the room acoustics.
post #12218 of 19461
When you used the crossover input you did have the knob turned all the way to the right, at the 150hz setting right? I've noticed my empire can sounda bit boomy at times too, even in different spots that my other subs didn't.
If he had the crossover on the sub all the way up to 150 it shouldn't matter which input he uses though right?
post #12219 of 19461
No, not if it was all the way to 150Hz. But it definitely sounded like it was much lower than that, from his description.
post #12220 of 19461
True. When I plug mine into the crossover input, and turn down the sub xo to like 100, it seems like my bass is less boomy as well. It is almost too boomy now. I know that would cause havoc with the FR, but it does sound a little better that way IMO.
If I end up actualy doing that, I may just be better off to use a lower xo in the AVR instead of on the sub. But then I would be loosing one of the empires best strengths, its midbass.
post #12221 of 19461
I just pulled the empire way out from all the walls and it actually sounded a lot better as far as boominess goes. I think with the sub having drivers on both sides, most times the person, including myself, will actually have one of the drivers facing the wall. With a single driver sub, people barely ever do this. Even when corner loaded, the driver is never actually facing the wall with a sub like the PB13 for example. That could be why some people are complaining of boominess.
Even when the sub is just along the midpoint of a wall, with the drivers facing to the sides, the wall is still in close proximity with both drivers, also possibly creating boominess. When I get my other empire tomorrow, I will set them both up in the center of the room, far away from all walls to see how the SQ is. My guess is it will be alot better than being near the walls.
post #12222 of 19461
How did it go? I'm not too far from you and things didn't look too bad around 7pm. If you managed to get them, with everything closed today, I guess you'll have plenty of time to play with the new toy. Enjoy!
post #12223 of 19461
A 2nd Empire will certainly make a difference. I have never gotten any boominess at all. I'm finding the best placement for me (and this is generally the case for most dual sub set ups) is in front and back of the listening positions, centered on the walls. 12 and 6 oclock with the listening position in the center facing 12 oclock. About a foot from the wall. After alot of trial and error with placement and EQ, I'm getting very tight deep bass. The U571 scene is incredible.
I have to say the empire was very different for me. With my 12 years used to my old velodyne, I realize it had way exaggerated sound at around 40hz, which I thought sounded great. It was very plug and play. The Empires have great output at all sub frequencies, just a better sounding sub. Admittedly, my house curve/EQ has the low end slightly bumped but that's a preference call. I think I might level this out slowly over time.
This weekend, I'll try room corner stacked.
post #12224 of 19461
I spoke with Chad on Monday, nice guy, anyway decided to order 4 empires. They were delivered yesterday. I have been running 2-SVS pb plus 2's. I set 2 empires on the front wall at 1/4 distance from the sidewalls, and 2 in the rear same distance. I dialed each sub to 75 spl individually, then turned on all 4. I then ran audyssey eq. My room is 23ft x 17 ft with a 10 ft ceiling.
This is the best bass I have ever had in my house.
The dual SVS's are phenomenal, however the sound quality difference, and the tactile difference with having 4 subs in room is just stupid.
Headroom in spades. As an example. Scenes I used to watch with dialog at 70, would have peaks around 108 in my room. Now, same scenes, dialog at 65, peaks at 111. And the crazy thing is, it doesn't sound as loud. You feel it more. It is just effortless.
Same thing with music. The headroom, and dynamics of my enitire room have changed.
I have been interested in upgrading my room for quite a while. I am considering some very different set-ups, i.e. Danley, Seaton, or JTR. On a whim I decided to try 4 empires. All I can say is at this moment, I have no desire to change my sub's. This set-up, in my room, gives me clean effortless lfe.
David
post #12225 of 19461
Thanks for sharing your experience David. I think you're the only one to own 4 Empires and post here in the Epik thread.
post #12226 of 19461
Dumb question. Our really nice sub reference list contains 2 Epik's that I've been looking for, especially the Valor. When I check their site, all I see is models newer and most out of stock with no orders being taken or labeled as discontinued. Where can I find ratings / reviews of current designs? Are they even available? I'd love to find a used Valor or Castle but that's tough to do. Is there a Valor replacment that I can get for $600 shipped? If not, what do you guys suggest? Not in a real big rush, but their site having only the top ot the line shown as available concerns me. thanks. Joe
post #12227 of 19461
From what I've been reading, the only model currently available from Epik is the Empire. All the other listings are discontinued. Evidently they're working on some yet unannounced models.
post #12228 of 19461
David
Nice. I too am considering 2 more epiks. Just to have the perfect 4 sub set up. Damn you and your good review! I wonder if Chad would cut a deal for 2 more ...
post #12229 of 19461
Awesome feedback! I had a Velodyne and went Epik, and I too got used to that peak in the 40Hz area!
BTW, as the subs (and your ears/mind) "break in" a little more, you will notice that you will hear it a little more as well .
What sub EQ did you use?
I am still having a little trouble dialing in my Epik Sentinels.
http://www.avsforum.com/avs-vb/showt...0#post18209180
post #12230 of 19461
I'd love to find a used Valor or Castle but that's tough to do. Joe
I am planning on heading into the DIY subwoofer world soon and will be replacing my Valor with a new ported DIY design. At that time I plan on selling the Valor. Unfortunately, that probably won't be for at least a few months from now.
I agree it is odd the product lines have been completely overhauled twice in such a short time. However, most Epik owners (myself included) will tell you that Epik products are excellent performers for the money.
If you are still in the market for a Valor in a few months and my DIY plans come together, perhaps we can help each other out. Good luck on the search for the subwoofer that will make you happy. The search/research is half the fun.
post #12231 of 19461
I'm using the BFD1124 which is great. If you go the bfd route, I highly recommend getting midi cables so you don't have to dial in all the settings manually.
I just noticed your other thread. Did you get an PEQ for your subs yet? If not, you can get the 1124 for $85 shipped from B&H or do what I did, print out the B&H ad and take it to Guitarcenter for a price match.
post #12232 of 19461
Frankly speaking I am not sure where you are going to get a reference sub for $600. When you find one let me know. I need another to go with my Empire.
post #12233 of 19461
I did, thanks! Yes, I have taken advantage of the MIDI port and REW with my DSP1124p.
Here is a link summarizing some of my concluding points:
http://www.avsforum.com/avs-vb/showt...7#post18097407
post #12234 of 19461
I've got 2 Sentinels in a 4400cu.ft.carpeted rectangular room with openings in the middle of both long walls and another in a rear corner. There is a lot of discussion here about moving subs around for best sound, but nothing about how to run wires from the receiver to the subs. Any secrets here? Oh yeah, poured concrete pad and 15 foot peaked ceiling.
post #12235 of 19461
It shouldn't be too hard if you have baseboards. If you do you can always pull them off and there is usually a gap between the Drywall and the floor where you can stash a cord or more. It will take some careful planning. All in all if you are in a room that is drywalled or paneled without baseboards or door trim of some sort you are going to have to do some panel removing and/or drywall patching and floating. Without doubt this is a pain in the @$$ but just for anything else nice there has to be some sacrifices made in some way or another. Most wives are not opposed to a fresh paint job in a room.
Cheaper options are area rugs that can sit on top of wires. Slightly tacky but always an option.
Running under furniture of course.
On a side note there is wireless options out there....I don't many raving reviews about them but I guess they still serve a purpose.
Just my thoughts.
post #12236 of 19461
Just my thoughts.
I read that the wireless options are getting better but expensive at $100 to 150.
post #12237 of 19461
Deep, which Velo did you have and what were the rough specs?
post #12238 of 19461
Velodyne DLS-3750. Roughly: 175 watt amp, 10" driver, slot ported sub that was really a great performer for its size and specs.
http://www.avsforum.com/avs-vb/showt...1#post17692081
post #12239 of 19461
Deepstang, are you glad you went with the BFD compared to say trying the antimode or sms-1??
post #12240 of 19461
Thats interesting. My velo was a va1512, 12" w/15" passive radiator, 250watt (750 peak) ... odd, perhaps velo intentionally bumps up around 40hz.
