AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Epik Subwoofer Thread
Official Epik Subwoofer Thread - Page 417
post #12481 of 19462
Originally Posted by TnTBigman View Post
Hi michwill36,
What receiver are you running? Mabye you're running it too hot. After 1 o'clock on the Empire's volume knob it starts to sound muddy even with my receiver's sub level out at -2.5. Make sure you've got it plugged into "LFE in" and not "Crossover" at the back of the Empire. It might also help too if the Empire's Crossover knob it turned all the way to 150Hz.
Like Hksrv4 said, you'll have to play around with placement and listen from the Listening Position (LP) to find the best spot. A first step would be to place the Empire at the LP and go around the room noting the spots where the bass sounds good. Hopefully you'd be able to place the Empire there. Lets us know your findings.
I concur with this. It took me a couple of WEEKS to get my positions right. Even today I want to try different spots. I like the trial and error though.
When I first got my Empires, I heard all this extra "stuff" coming from them and I was like wth is that? My old velo just did a bad job at producing good midbass. This is what I was hearing and at first thought, this isnt bass! But then with some trial and error, and some bfd eq, I am now appreciating what real bass is.
A good test for this is the gas station scene in terminator salvation blu ray. OMG, the robot sounds are incredible. I crossed over at 100hz and the midbass (as well as the sub 20hz) is just awesome. A couple of other good ones to try is the U-571 depth charge scene and the opening scene of Star Wars ep2 ... the big ship flyby and when it explodes after landing. Good demo stuff there.
It might take you a day or two to learn to appreciate the different sound of the Empires. I strongly suggest a form of EQ as well such as the bfd1124 if you don't mind the learning curve.
post #12482 of 19462
On a related note, those of you with Empires (especially duals) what position is your gain knob on the back? Mine is around 11:00 for each Empire but I have to cut back on the receiver's (onkyo 905) sub trim by around -9db. I'm thinking of getting that closer to 0 and reducing the sub gain to around 10:00.
I know, all of our rooms are different and will require different gains but was just curious. Also what size is your room.
post #12483 of 19462
Also coming into play is the reciever / prepro calibration. What are you using? Do you rely on the reciever / prepro to handle the sub eq or do you have a standalone unit and what is it? Alot of factors coming into play to get the perfect SQ from a sub(s).
Bill
post #12484 of 19462
Well I got mt dual Empires today!
ATM they are a bit of a muddy mess w/ both of them hooked up...one is ok,but 2 is muddy.
I'm not going to mess w/ them too much as I ordered an SVS EQ 1 last night,so I'll just wait till next week when it comes in and then start tweeking.
Anybody want to buy a Polk sub? LOL j/k. I'm gonna keep it and use it for my bedroom surround system.
post #12485 of 19462
Originally Posted by jmurfk View Post
I plan on putting an Empire in a 20x24 room with 11' ceilings. I'm coming from a bose base module, lol. Right now I only want a single and may add a second later. Just want to hear and feel the bass.
What are some of your experiences with a single empire in a large room?
My room is 18x22, 14 ft cathedral ceiling, half open to the rest of the house. I have one empire in the front right corner, firing front to back, about 2 ft from the front wall, 17 ft from where I sit. The gain is 11:00, LFE is -3 at the receiver. This gives a 79 db test tone w/the rest of the speakers at 74. The bass is so clean it doesn't seem hot at all. W/ the MV at 0 (louder than I usually have it) I get 110-112 db peaks at the LP during movies.
I'll admit I was a bit underwhelmed with the Empire at first, but I don't know if it was break in or tweaking, but I like it more every time I listen to it. I can't think of a better out of the box bass value under $1000.
post #12486 of 19462
ive got an integra 7.1 receiver 6.3 model. i had it plugged into the crossover. i got it plugged into lfe now. i can hear muddy voices coming out when im watching tv. why is that? i got volume at 11 oclock position too. i have my crossover on reciewver at 100.
post #12487 of 19462
I was hearing that too until I turned my xover down to 80hz.
post #12488 of 19462
Male speaking voices typically have a good deal of content in the 100 Hz range. But they also have overtones far higher, and of course the sound of an "s" is going to be 2000 Hz or higher, depending on the person. The part of the voice that is below the crossover will go to the sub. The higher tones will not. So if you just listen to the sub, it will sound muddy. But appropriately setup, it should all come together fine.
post #12489 of 19462
Whats the distance from the speakers to the main listening position? We share nearly the same volume room, but mine's is more rectangular (37x15x10). My LP is 13 ft and the Empire does pretty well on it's own.
I'm probably around 12'. You have one empire it that size room, and your satisfied with the output?
post #12490 of 19462
Thanks. Just the response I was looking for.
post #12491 of 19462
I'm a bit spoiled since I have a bigger ported Epik Tower there as well. On it's own for music the Empire is really good-much better than the Tower. For HT it just lacks some low end "house shaking stuff" that the Tower handles with ease. If I didn't have the Tower, I'd go for two. Currently saving to get another Empire.
post #12492 of 19462
It really isn't a bad sub for under $1k but it really can't produce the slam that most want in their home theater. You can buy two but most likely you would need 4 to make an impact. Just my two cents...
post #12493 of 19462
hey getech what do u have your speakers set at? -3 damn why dou tou set it back that far ? i wonder if i could do audessey on a receiver several years old? my room is 22 x22 ft
post #12494 of 19462
huh?
post #12495 of 19462
Just checking in..... still just running a single Dragon (sealed 18") with zero problems to date. I still don't wish I had "more bass." I'm still as happy as can be. It's been a full year with this beast.
I just checked out Epiksubwoofers.com and apparently they don't even make the Dragon anymore? News to me.. can someone please tell me why they discontinued it? What have I missed in the past year?
post #12496 of 19462
They discontinued everything and came out with a single sub, the Empire. We expect Epik to come out with a few additional models and options at some time down the road.
post #12497 of 19462
Eh, I'll have to disagree there. For me, there wasn't any type of output I could not achieve with proper EQ and placement. I was able to get all the slam I wanted after a BFD and there's plenty more headroom. And this also depends on room size. Put a single empire in a 12x14 room and it'll dig deep. For me, with 4000cft open to 6000+ I'm getting tons of impact with duals.
My LP is very less than ideal. I can't imagine what some room treatments in a dedicated home theater how great they'd sound.
post #12498 of 19462
I don't disagree... I didn't mention that on the other side of the TV I have a coat closet facing the back of the room. On the floor I have 2 svs PB10's, a velodyne spl1000R & 800R that I run with the empires just for movies. (the db measurement in my previous post was the empire alone). It's almost enough but not quite. It's a sickness!
post #12499 of 19462
Same here. It's still amazes me everytime.
post #12500 of 19462
After some trial and error (and clipping on the BFD1124!) I have mine at about 10:00 and -7dB on my prepro. That has them all balanced separately at 75dB and then summed @ 75dB.
post #12501 of 19462
hehe, sounds like it is!
I don't get it though ... have you guys EQ'd your empires to give you the sound you're looking for? I mean, it's a sealed design just waiting to be tapped.
Let's not fault the capabilities of the sub if your EQ skills are lacking ...
post #12502 of 19462
I was at a concert last night at the Chicago Theater (Hendrix Experience) with dual drummers playing at times and some great bass players (Billy Cox from the original Hendrix Experience) as well as some awesome guitar players (Joe Satriani, Eric Johnson, Jonny Lang, Kenny Wayne Shepherd, Vernon Reid, Brad Whitford, Ernie Isley). Awesome show by the way. The last time I was at this theater seeing Chickenfoot I realized that what I was missing in my HT was the kick in the chest feeling I got at live concerts. I had plenty of low end impact and rumble but I never really felt that punch before. Now I have the dual Empires I can honestly say that what I felt at that show last night is what I feel in my HT now. Success!
post #12503 of 19462
Originally Posted by kevinzoe View Post
Anyone know the slope of the Empire's low pass filter (e.g. 6/12/18/24 dB)?
It has a 24 dB/octave slope.
post #12504 of 19462
Don:
Don't have dual Empires but had dual Valors and have set gain structures for many amplifiers driving passive subs so I hope I can chime in.
Is there a specific issue you are trying to resolve? (If it ain't broke, don't fix it philosophy) I know we all like to tweak (do we all have OCD? ) just asking.
In my experience, where you have things set is better than the direction you are considering.
Comments on gain structure
More comments on gain structure
post #12505 of 19462
Originally Posted by robobob View Post
Don:
I see ... I was just bothered by the fact I had to reduce the receiver's sub gain so much. I guess I was worried from a distortion point on view. My mentality is closer to +/- 0db is less distortion? I don't know, I'm a newb!
post #12506 of 19462
Are you speaking from experience or are you basing that off what you've read on the forum? Not trying to be harsh, I'm just curious if you have one and feel it's lacking for HT. My single Empire has more than enough HT "slam" and it has to satisfy approx 4,500 of cu ft. So I wholeheartedly disagree with your statement that most people would need 4 in order to get sufficient output. True there is a population of folks who run 4 subs but they are the minority of audio enthusiast. And to look at it another way, another user compared two empires to a Submersive and the empires bested the Submersive in the output category. So saying you need 4 empires is like saying you need at least two Submersives for adequate output.
post #12507 of 19462
Thats another factor that comes into play. I have my 6 year old Promedia Ultra computer 5.1 speakers in a 10x13x8 room and the pressurization is ridiculious. I've measured individual test tones there and 40Hz has a +10db jump from the rest at 75db. I can only imagine what a Tower or Empire would do there. Not everyone has the same dimensioned room, and some rooms are not ideal (opens to other spaces etc)- so same sub performance would vary. Not to mention one's sub history and tastes comming into play (perception).
post #12508 of 19462
has anyone had any problems with empire. i listened to mine for 30 minutes and it has quit. just got it. green light is on u can hear it turn on . it quit during a song at low volume.
post #12509 of 19462
Is it on "auto on" ? Mabye the signal strength from the receiver's LFE OUT is below the threshold that kicks in the Empire's amp "auto on". I've had no problems with my Empire.
post #12510 of 19462
That hump could be the room, and it could also partly be an artificial hump from the sub itself. Companies that make subs and woofers that don't very deep compensate by inflating the response of frequencies the speakers can do to give the impression of more bass.
My factory car stereo has a bad bass hump, either the system and/or the acoustics of the car, and I have bass turned down 4 notches (and mid and treble up 3). The boomy bass sounds bad with the rock n roll I listen to, although that boosted bass region sounds fine, and good even, with dance/hip hop type music. Even my $100 2.1 computer speakers have terribly boomy, exaggerated bass, where I have the bass down 50% below mid point, and mid and treble up 50%.
There are a lot of cheaper low-end brick/mortar subs that don't go very deep but fake having a lot of bass with boomy, exaggerated response, instead of the (much) flat(ter) response the nicer subs and the good ID sub brands deliver.
