Originally Posted by FrostyMMB
REW is extremely easy to use. Just read the manual to calibrate your soundcard and mic, and from there on out the software will handle the sweep and measurement at the press of a button, and you can adjust the parameters of the sweeps and tones if needed. I see no benefit in attempting to use a CD rather than allowing REW to do all the work for you. Give REW a try and forget about the CD.
Frosty ok thanks just seemed like a lot of work having to find a mic and all. Can't find where it explains what equipment I will need? Like what type of mic? Where would you find mics for this?
.........thank you again
