Originally Posted by GPowered
Very Interesting. I have a question as I am a little confused though. I have Audyssey Multi-EQ and Dynamic EQ (basically the same thing except it helps at lower volumes). It is my understanding that Audyssey sets levels, distance, type (x-over setting although this is generally more of a personal preference), AND helps to smooth out peaks and dips, etc.
Since you are running Anti-mode, what is the point of using Audyssey in addition to it? Anti-mode will smooth out FR and the levels, type, distance, etc. could be set with an RS Meter. Let me know because I was under the impression that Audyssey may not do that good of a job smoothing things. Is the Anti-mode worth the investment if I have Audyssey?
I have received good results regarding Audyssey MultEQ XT and my Tower/Dynasty and others will tell you that you don't need Anti-Mode with MEQXT. The best way to tell how your FR looks is with something like REW, which will show you a graph of your nulls and peaks. You can just use Anti-mode and disable Audyssey, but Anti-mode will do nothing for higher freqs. So, many people who have AM use Audyssey in combination.
