AVS › AVS Forum › HDTV › HDTV Programming › HD syndication ... more on the way
post #1 of 384
Not sure if this has been mentioned anywhere, but if it has, I haven't seen it. There's been a lot of talk here about HD syndicated programming (or lack of), so I thought it would be interesting to note that Warner Bros. will be making the syndicated episodes of "Two and a Half Men" available to stations in HD when it debuts in September. The episodes will be delivered via Pathfire.
There may be other shows that are getting the same treatment, but this is the only one I've heard about so far.
post #2 of 384
Isn't that basically what HDNet is doing with those HD series it licenses?
post #3 of 384
HDNet is different -- they just get their own copies of the shows and keep them in their library. Syndicated shows are sent down everyday, and are re-sent for each airing as there is integrated commercial content which changes each time.
post #4 of 384
Syndication is an entirely different ballgame. See the Jeopardy in HD thread for details on why doing syndicated programs in HD has been a big hurdle to climb. This will eventually lead a whole lot more HD programming over the course of the day at your local broadcast stations. Would be nice to see CSI reruns or the redone Star Trek TOS episodes in HD or even Seinfeld at some point in 4:3 OAR HD.
post #5 of 384
That's the way I see it too. Since the majority of syndication is done through Pathfire, this means that there will now be a relatively painless way to move this content to the stations. Now the station(s) will still need to invest in an HD server and ancillary gear to get this stuff on the air, but this a good sign that things are about to change ...
post #6 of 384
Just curious, if a station is airing Jeopardy or 2.5 Men in HD, do they need to download an HD and an SD feed for air later? Or can they just downconvert/centercut an HD feed to create the SD one? Seems if they could do the latter, it would make the whole ordeal slightly easier.
post #7 of 384
The answer is, "it depends." Some HD servers can provide a simultaneous SD output, which can either be letterboxed or center-cut. Barring that, they could use an external downconverter to accomplish the same task. If neither of those are possible, then recording two different copies would be required.
post #8 of 384
Has anyone heard anything about shows like "Live With Regis & Kelly", "Oprah" and "Ellen" being made available in HD?
Larry
SF
post #9 of 384
I remember there was a rumor about "Oprah" awhile back, but I've not heard it recently. The place I work for doesn't air any of those shows, so I don't have any inside scoop on what might he coming down the pike.
post #10 of 384
Originally Posted by videojanitor View Post
The episodes will be delivered via Pathfire..
Only if you're willing to spend the money to upgrade your pathfire servers to HD..
They don't provide that upgrade for free..I have 3 of the beasts to do..
post #11 of 384
Where?
post #12 of 384
Originally Posted by vertigo235 View Post
Where?
In the pathfire rack of course.. .. Here @ WCCB-WOLO..and that doesn't include the other 4 stations In our group...
post #13 of 384
What will that bring to WCCB?
I ask obviously because I'm in Charlotte!
post #14 of 384
What will that bring to WCCB? !
ABSOLUTELY NOTHING.. as the ONLY syndication we air that is currently available to us in HD is Wheel & Jeopardy, and that airs on WOLO... Which is why I won't spend the money to upgrade pathfire..
post #15 of 384
Hmmm, this is interesting, because our station received a communique from them to let us know that they would be upgrading our servers to HD this weekend. It's just a software upgrade -- no hardware. I had not heard that there was any cost involved for this, but then again, I don't hear everything. Perhaps this is because for this particular upgrade, they won't be supporting VIDEO playout of the HD material -- you've got to have HD servers that will accept the content via file transfers.
post #16 of 384
Yep, and that's a whole nother kettle of fish.. and usually involves "file-wrapping" via additional pathfire or Telestream software..again, mo money..
post #17 of 384
Contrary to what bdfox18doe mentioned, there are a few other syndicated programs that are simulcast in HD. In my market, we get Comics Unleashed as well as National Poker League and Laura McKenzie's Traveler in HD. So, yeah; it's slowly growing in terms of local programming (aside from HD news). So far, so good. Heh.
post #18 of 384
Out of interest - does anyone know what codec and datarate Pathfire uses for SD and HD content? Presumably it spits out an SDI or HD-SDI signal (or does it have file based transfer options for transfer to suitable servers?) but I assume it uses compression for distribution?
I've been involved in a system used in the UK for distribution of commercials and music promos in SD that is based around 50Mbs I-frame only MPEG2 (not massively different to 50Mbs IMX I guess) and that is pretty good quality - not noticably worse than DigiBeta.
post #19 of 384
I can't get info on the original files, but when they're transcoded and deposited in our air playour servers, the SD files are between 10-12 Mb/s, while the HD files are 37 Mb/s. Their workstations can output SDI, but not HD-SDI -- if you want the HD content, it has to be done via file transfer (for now ... I believe they will be offering HD-SDI playout in the future).
post #20 of 384
Hey Bill, are you guys airing any syndication in HD yet?
Still the only thing "WE" air that's available to "US" (contrary what teamfx says) is W & J..There is one PAID programmer we have on both stations that is moving to HD, but they have been saying "this fall" for the 2nd year in a row now. Can't name them as they haven't officially announced HD. But they have bought the equipment, and will use satellite distribution as they do now.
post #21 of 384
Indeed. We are airing "Two and Half Men" in HD, twice a day. As far as I know, that's the only thing on our schedule (outside of FOX, which doesn't count) that's available in HD. I had read earlier this year that "Merv Griffin's Crosswords" was supposed to be HD (at least on the NBC O&Os), but I can't find any evidence that it is.
post #22 of 384
I know you won't confirm, but lemme guess: Is it a church?
post #23 of 384
Merv Griffin's Crosswords isn't in HD on WMAQ btw.
post #24 of 384
My guess from unofficial rumblings and rumors would be more of a club, than a church.
post #25 of 384
And might this "club" upgrade to a 14:9 "right" justified transmission, and not transmit anything on the "left" side at all ????
And might they change their name to "The 720p Club".
Sorry, couldn't resist.....
post #26 of 384
4:3 SD here on WNBC.
post #27 of 384
Is anyone airing the HD remastered Seinfeld in syndication?
post #28 of 384
The answer to that seems to be no, because they are not being made available. The syndicated episodes are sent out daily (because they include different national commercial content with each airing), and as far I know, they don't have HD syndication versions.
post #29 of 384
I guess it's time to start hounding the powers that be until we get our HD Seinfeld.
post #30 of 384
You would think that someone would realize that having these in HD would actually add value to the reruns -- it would at least give you a reason to WATCH them. I know if they were in HD, I would watch -- whereas I don't now.
  Back to Forum: HDTV Programming
This thread is locked
