Originally Posted by nickdawg
What are the good sides of the splicer system? Other than it is supposed to help keep HD on the screen(a digital feed is always sent along with the analog and it is supposed to automatically show HD during network programming). It seems like this system is more of a PITA than helpful.
Cost. A station doesn't need to have HD digital infrastructure to air Fox in HD. I think Sinclair had a hand in this, as they own many stations and many of those stations are analog plants. I do not know the exact count. Our local Fox affiliate is 100% analog. If it weren't for the splicer, I doubt that Sinclair would have spent the money to get this station broadcasting in HD. We are low on Sinclair's radar.
Sinclair only needed to spend money for an HD encoder to take the SD analog and turn it into upconverted HD. Fox paid for everything else.
Fox doesn't send analog anymore. All of their feeds are digital, just like all of the other networks. One receiver gets the SD feed and sends it to another box that gives the analog station the analog that they need. The other receiver is the HD receiver and that ASI output goes directly to the splicer.
As for automatically switching to the network HD feed, that is still handled by the affiliate. A tally output from the master control board goes to the splicer, When "net" is punched up, the tally signal tells the splicer to switch to the HD.
The same type of automation is done at stations that are 100% digital. A tally outpur is used to control switchng from local content to "net" content. The splicer doesn't add anything of value there.
The other reason for the Fox system is that the local affiliate isn't re-encoding the HD video that is being sent to it. All of the encoding is done is LA. Turns out, IMHO, that has not worked out. Because there isn't enough bandwidth on the current digital mux, since it has 4-SD and 4-HD streams, macroblocking of the video is a common occurance. Especially during fades. Also, they set aside space for the affiliate to add an SD stream. Even if the station doesn't do that, everyone suffers with the same low bitrate. When SD goes away, that will give Fox more bits to work with and hopefully the video quality will improve.
It also gives Fox affilaites DD5.1 capability, for network shows. For those that aren't willing to spend the money, like Sinclair, we viewers still get DD5.1 audio.
This also makes me wonder what will happen after February 2009 when the SD analog feed is no longer there to 'throw back to' for local inserted weather warnings. Will all stations have to make this upgrade before then? At a cost of 30K? Since the HD feed will also be used as the SD feed, I don't think they could go without broadcasting weather warnings.
At this point in time, Fox affiliates are not given access to use the HD video and centercut and downconvert to analog. While stations do have a monitor connection to the HD feed, it is not in the video format that stations can use. Then there is the problem with audio.
Stations like my local affiliate are either going to have to spend the bucks (Sinclair will kick and scream) or Fox will be forced to provide downconversion gear to provide NTSC video and stereo audio for those analog only stations.
And that splicer system is also bad whenever local station decides to over ride it and show SD anyway. The entire evening was SD, even local news.
Local news in my area is SD. No one is doing HD news yet. If the local news was in SD and your news is normally HD, then something else was wrong at the station. The splicer cannot cause local content to be SD upconvert. Only the station can do that. There might have been something drastically wrong at your affiliate that night.
