I picked up a used VP4001 that had taken a knock on the focus ring, which cracked the plastic focus ring itself pretty badly. But the rest of the lens assembly looks undamaged. It appears the focus ring took the shock itself.
And after checking out the projector, testing some DVDs, all seems fine. The lens assembly zooms and focuses fine, etc. as well.
But here's my question: Is is normal for the lens assembly to have about 1mm worth of side-to-side "wiggle" while one focuses, or should it normally be "rock steady" through its focus range?
At this point, I got a partial refund for the projector, it came with a new lamp, and it does seem to work so even if this "wiggle" is abnormal I guess I can live with it as it doesn't seem to affect the picture. But I'm just curious if there normally is a tiny bit of play or not.
Although if "not", I wonder if there is some adjustment inside to tighten the lens tube back up?
Al
Al
