AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › LG BH100 problem with standard def disc
post #1 of 3
Hello all,
I have a BH100 connected to a 42" Sony LCD projection set via a Monoprice HDMI switch (manual version for two devices). I hadn't noticed any problems with standard def discs before, but the other night I was watching Zodiac and there seemed to be some slight image stutter and poor upscaling.
I haven't done full scale testing by connecting the BH100 directly to my TV, but before I go through the trouble I wanted to find out if anybody else has had similar problems.
Thanks in advance,
TOHO
post #2 of 3
Nope !
Athanasios
post #3 of 3
I never tried an SD DVD in my LG.
In any case: 1. Make sure you have the latest firmware. That's a good idea no matter which problem you are having. 2. If you are having problems with only one disc maybe it's the disc. Have you tried the same disc on another player?
  Back to Forum: Dual Format Players
