AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Dual source speaker selector question
post #1 of 2
According to the Jamo website:
JSS6-HP
Dual Amplifier Hook-up
A second amplifier can be connected to the speaker selector, if additional amplification is required. Furthermore, this feature allows you to select between amplifier A and B for each source.
What does "if additional amplification is required" mean? I understand what it means to select between an amp "A" and an amp "B" for different sources. However, does this also mean that you can give the speakers an extra boost? The problem with this, as I see it, is that the front of the selector has an A / B switch, that appears to be either on a or on b. But, not both at the same time.
I have the selector . . . just took it out of the box, to be installed in a couple of weeks.
post #2 of 2
Try posting this in the Speaker forum you will get more and better responses there.
