AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › IS 1.5mbps fast enough for streaming?
post #1 of 12
So my roommate and I just moved into our new apartment and the only internet we could get was bellsouth at 1.5Mbps. is that fast enough to stream to an xbox 360 wirelessly ?
post #2 of 12
You stream through lan (your connection inside of your room), not thru internet...
post #3 of 12
oh ok... yeah ive never ever done anything like this in the first place. is there a way i can do it wirelessly?
post #4 of 12
or can i hook up a router to my computer and then the same router to my xbox 360 and do it that way? is it better to just get a cheapo router instead of the expensive wirless adapter for the 360?
post #5 of 12
IMO wireless is not good very distributing video. You would do fine with low res stuff, but IME anything with quality will not work reliably over wireless.
post #6 of 12
well, if you use Wifi/N with the sender and receiver close together, you might be ok. What are you looking to stream?
And by the way, you can stream stuff off the internet. It's usually fairly low bandwidth, though.
post #7 of 12
well i just got my internet hoked up in my apt and i ahve my computer wirelessly hooked up to my internet and my 360 hooked up to the wireless router via cat 5. i just wanna stream videos and music that i have downloaded. i can hook my comp up to the router with a kat five but not till tomorrow
post #8 of 12
If the router and the 360 are both hooked up to your router via CAT5 you are good from a networking perspective. much better than wireless....
Sean
post #9 of 12
yeah it is working ok, but for some reason tversity keeps shutting itself off or just stops streaming and then sometimes my xbox cant always find my computer because tversity is not working. any help would be nice. thanks fellas
post #10 of 12
anyone?
post #11 of 12
The problem may be that your PC drops the wireless connection to your router every so often. That is a common problem, especially when the router and your PC's wireless client are made by different companies. Be sure that your router is updated to the latest firmware, and your PC's WiFi hardware has the latest drivers. Also, it often works best to use Windows built-in Wireless Zero Configuration to run your PC's WiFi client than whatever software utility the WiFi manufacturer provides.
post #12 of 12
but im not hooked up wirelessly to anything all cat5
