post #1 of 1
I'm finally ending this, I've decided I'm either buying a Slimfit TXT3093WH/TX-T3092WH OR a Vizio VX32L LCD. I'm assuming the Slimfit will have the advantage in black levels and shadow detail but the Vizio will be sharper. The Vizio has great color from what I've seen so they should be equal in that department. I'm also a little worried about the Slimfit breaking down or having terrible geometry issues. Which do you think will look the best overall? It will be used mostly for gaming in my dorm and maybe some movies on Blu-Ray every now and then.
