Originally Posted by
maxpower2078
Yeah, that is what I thought, it's the Philips DVP5982. I got it for the Mpeg4 playback and see how it could do on up-conversion
I did a find on the PDF manual for "DTS" and there aren't any results. What do you expect I guess, it has its purposes.
Alright found it, it does, just weird they don't mention it in the manual.
If you want to enjoy DTS sound on the player, you will have to connect via Coaxial to a Multichannel Receiver or connect via HDMI to a HDMI Receiver.
Connecting via Coaxial to a multichannel receiver:
1. Press SETUP on the remote control. The system setup menu appears.
2. Press to select { Audio Setup Page }
3. Press to select { Digital Audio Setup }, then press
4. Press to select { Digital Output }, then press
5. Select { All } and press OK
Note: When using Coaxial output, HDMI Audio has to be set to { OFF }.
Connecting via HDMI to a HDMI Receiver:
4. Press to select { HDMI Audio Setup }, then press
5. Select { ON } and press OK
Ok, now to get back on topic, can't wait to get the A5-350 home.
