Well I picked up a Yamaha 3800 after having gone through a Sony 5300, Elite 94 and Denon 3808. The Yammy is a keeper!
I was really growing weary of different issues with each of the receivers. The Sony had HDMI switching issues, inconsistent ability to switch to the on-screen GUI from a 1080p input and some trouble with initiating Dolby True HD from an HD DVD player.
The Denon just didn't sound good to my ears although it didn't have the Sony issues. The sound was too thin with a lacking in the low end.
The Pioneer sounded great, but I wound up having lip synch issues with the advanced audio codecs. The problem here is that the lip synch setting on the Pioneer is automatic and can't be adjusted. So it either works or it doesn't and you can't intervene to nudge the delay so that everything looks right. Some people aren't as sensitive to lip synch issues, but when you are, you just want to turn the TV off.
Enter the Yamaha. It works! It sounds superb with tons of low-end output! It does everything it's supposed to and allows all sorts of adjustments many other receivers don't. Even something as simple as a 'trim' adjustment to equalize the volume of all your sources, is missing on most receivers. The Yamaha has it.
The lip-synch adjustment is more sophisticated than any other receiver I've encountered. Very nice! I just wish they would have allowed a unique adjustment for each input. But as LovingHD said above, you can store unique settings in the memory slots and then have your remote do a macro when you switch sources.
I've had a number of Yamahas in the past and I guess in retrospect this should have been my first 'look-see' at a new HDMI switching receiver.
