AVS › AVS Forum › HDTV › HDTV Technical › Indoor HDTV antennae recommendations..
post #1 of 3
Preferably something I can purchse in store. Thank You.
post #2 of 3
Are all the digital stations on UHF or are some on VHF? Will any of your local stations be switching to upper VHF or low VHF in February, 2009? Are all the stations in the same direction or are they scattered around you in azimuth? Are you close enough that an indoor antenna will work? If you provide your zip code, then we can provide useful advice on indoor antennas to try. If all the digital stations are on UHF and is the same general direction, the Silver Sensor UHF antenna design is a good antenna.
post #3 of 3
The type of antenna you need varies greatly depending on the distance from the towers you are trying to recieve, obstructions between you and the towers...etc. Some can get by with a cheap rabbit ear setup while others may need an amplified solution or even an outdoor antenna. Check out www.antennaweb.org for what you need in your area.
  Back to Forum: HDTV Technical
