Originally Posted by sethhobrin
I have a thermaltake 700watt modular PSU with a 120mm fan inside the psu. Personally I installed the PSU so the fan is pulling air from inside the case and exhausting outside instead of having the fan facing the side grill for fresh air. The PSU may get a little bit more hot but I'm sure I can handle it and this way I have more fans exhausting the hot air from inside the case especially if your loading up on drives and a good GPU. I would definately 100% recommend installing silent 92mm fans below the hard drives.
I had an NEC burner that didn't have any clearance issues. I just got a sata liteon lightscribe drive though which is much smaller(so I can fit a 8800gts) and I haven't installed it yet so not sure if there will be a different. I hope not.
Has anyone foudn any good programs for the LCD. I hate the imon software. I DONT want a friggin scrolling clock and i CANNOT figure out how to turn off scrolling. I just want a clock on ALL the time. Anyone know how to do that. I don't even care about all the fancy jazz. I just want a darn clock!
Thanks sethhobrin for reply.
I did install 92mm fan under 1 bay, where I put only 2 drives so far: WD750 GB RE2 and new Samsung F1 1TB.
It should be enough for now.
I placed PS to intake air from outside - will see how it's doing. One of the reasons to do that is I am going to install CPU aftermarket Heat sink Thermaltake CL-P0401 110mm Full-Range Fan CPU Cooler and Video Card cooler :Thermalright HR-03 GT with 92mm fan.
So, all area should get enough air around MB.
Plus 92mm fan under HDD's + 120mm Case fan.
I think it should be more then enough air circulation inside.
I got few ZALMAN FAN MATE 2 Fan Controllers as well and may reduce speed of some fans if anything going to be noisy.
I got LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06 and this drive didn't fit 100%. As I did increased holes of the brackets to bring it closer it looks too low as well. As I said yesterday, I am not sure it will be able open door.
I may test it later tonight.
Here is my setup so far:
1. SILVERSTONE Crown Series CW02B-MXR Black
2. Intel Q6600
3.EVGA 512-P3-N805-A1 GeForce 8800GT KO 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready
4.CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
5.LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06
6.GIGABYTE GA-X38-DQ6 LGA 775 Intel X38 ATX Ultra Durable 2, Ultra Cooling Intel Motherboard
7.SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM SATA 3.0Gb/s
8.Western Digital Caviar RE2 WD7500AYYS 750GB 7200 RPM SATA 3.0Gb/s
9.Thermaltake W0106RU Complies with ATX 12V 2.2 & EPS 12V version 700W Power Supply
10.Thermaltake CL-P0401 110mm Full-Range Fan CPU Cooler
11.Thermalright HR-03 GT
12.Logitech diNovo Edge KB
13.MX Air Rechargeable Cordless Air Mouse
14. Few ZALMAN FAN MATE 2 Fan Controller.
15.LINKSYS WUSB54GS USB 2.0 Wireless-G Network Adapter with Speedbooster.
Now, tell me it's overkill
that I actually ordered 64. I discovered it after installation and it's too late to return it, since package is opened.
