How much will be pushing the limits of the structure if that is possible? It's steal covered and reinforced with concrete (garage above) 13.5' x 20' room. There are two rooms next to it storage and the lobby. I have one and was planning for two or more if I can.
Originally Posted by crystalaudiovideo.com
The THX Select Certified 12'' THX-12SUB sets a powerful and dynamic foundation for immersive, exciting, you-are-there surround sound. The bass gives the soundfield of your home theatre system a true sense of space.
- THX 12-SUB Select Certified Subwoofer feature flat anechoic response from 35Hz to 200Hz and accurate in-room response from 19Hz to 350Hz
- Sturdy cabinet construction with internal bracing
- High quality, powerful built-in 200 Watt amplifier
- High Sensitivity 93dB/W/m
- Long throw woofers with serious magnets for a deep and powerful bottom-end
- Accurate bass performance to THX standards requires one THX-12SUB or two THX-10SUB subwoofers
- Automatic power off to stand-by after 10 minutes without signal
- Automatic power on when signal appears at the input
