AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official SVS Ultra 13 thread
Official SVS Ultra 13 thread - Page 225
post #6721 of 10036
It probaby will not bottom out, but if it did it would void the warranty. I heard it sound nice this way. But I would not try it.
post #6722 of 10036
Two SVS subwoofers.
I picked up a PC13 Ultra on Friday to go with my PC12 Ultra. I wasn't unhappy with the PC12 Ultra, but I kept thinking that a second woofer would help to smooth the response a bit. Apart from the fact that the PC13 is about 6 inches taller, thus destroying the symmetry of the set up, I am quite happy with the new addition. BTW, main speakers are Martin-Logan Vista's with a Stage center channel.
Per recommendation from Ed Mullen, I set the volume on each sub individually (using the AIX blue ray sampler test tones), with the PC12 Ultra about 3db lower in volume than the 13Ultra. I then ran Audessey on my Marantz AV-8003, and left it at that. As expected the addition of the second woofer decreased the subwoofer setting about 6db on the Marantz.
There is a difference in sound quality with the addition of the second sub. How much of this is due to the difference between the 13 ultra and the 12 ultra, I can't be totally sure. I did set the 13 ultra where I had the 12, and ran a couple of CD tracks before hooking both subs up, and it did appear to me that the 13 sound added a bit more texture in the bass than what I heard with the 12 ultra, but it was a short listen.
With both subs opperating, I definitely hear a better defined, and I believe smoother bass response. The bass in general now seems to be more a part of the music, rather than a separate entity. The bass appears to be more effortless, like it just happens, as opposed to being generated by a speaker. Stand up bass now seems just a bit more life like and bass drum and tympany strikes bloom a bit more than they did before. All this while at the same time reducing the bass node that I used to find near the little alcove where my turntable is set up (good thing).
We've only watched two movies so far (League of Extarordinary Gentleman, and Sherlock Holmes) and the improvement is noticable. The combined subs seem to go deeper, (both with all ports open) and with less effort. In Sherlock Holmes, there was some really deep stuff that happened when Holmes was visiting Blackwood in prison that made me and my wife turn to each other and go "wow". Same thing with some of the scenes in the League (which we had watched a few times before with just the 12 Ultra).
At the same time, even though the really deep bass seems stronger, there is a bit less boom, and the whole sound field seems more integrated. Gunshots have a bit more impact (We all jumped in seats during one part of Sherlock) doors closing just a bit more weight, but without overhang. All this at levels that are ~ 8db below "reference".
All in all, a satisfactory up grade, and if anyone is waffling about the merits of adding a second sub, my experience is that it is a worthwhile upgrade.
Chuck
post #6723 of 10036
Originally Posted by TheFactor View Post
Bottom out so easy ? LOL Your doing something wrong , i've never bottomed out my plus or pb13 and had my whole house shaking. Excuse me for saying so but you might have some sort of a bass deafness Of course you can bottom out any sub just being careless and or not having it setup properly just like you can over rev a Ferrari if you wanted to Do you even own one and if so which ?
post #6724 of 10036
Do the DACs in a prepro/receiver affect sound quality of a subwoofer or is the frequency range so low that for all intents and purposes it doesn't matter?
post #6725 of 10036
Originally Posted by cstory View Post
Two SVS subwoofers.
Chuck
Thank you very much for the review. I am in the looking stage right now also. I too have a PC-12 Ultra and am thinking about a second one for our theater. I have been searching for a use PC-12 Ultra to have two of the same also but so far no luck at all finding one. Looks doesn't really matter as they will be behind a screen wall, just though it would be nice to have them match. If you don't mind how big is your room? Our theater is about 2800 cubic feet.
post #6726 of 10036
Originally Posted by getech View Post
I get exactly what you're saying...I too am at 15 hz with my dual PB13's and can't seem to try out sealed. I get plenty of room shaking bass as it is.
Quick question. When you guys try different tuning modes, do you turn off the equalization features of the receiver (ie: Audyssey) first?
I would think that since it is equalized at a particular frequency you would not really get the expected results listening in a different mode (20Hz versus 10 for example).
post #6727 of 10036
You'll have to re-run the EQ/autosetup for any changes (location, tuning, etc.) However, I run straight stereo in full by-pass mode when listening to music, so asside from level settings, I don't change anything when re-tuning. I actually don't use any room EQ ever - I don't care for how it sounds when I move around the room, but ymmv. The levels will have to be changed when going to a different tune, as the lower tunes are less efficient typically.
post #6728 of 10036
The room is roughly L-Shaped (It's a basement). Total space is ~ 5000 ft3. The part of the room that we use for seating for the theater is ~ 1/2 of that. One leg of the L is framed in for storage, and contains the stairs coming down from the upstairs. There is a 8ft sliding door and 2 windows on the outside wall, the rest of the room is concrete block behind dry wall.
post #6729 of 10036
Two SVS subwoofers.
Chuck
Good to hear Chuck, once you go duals theres no other way ! Nice review btw !
post #6730 of 10036
Originally Posted by [unique] View Post
Im sorry hope I wasnt to harsh on you but to me when someone bottoms out a sub more than once this comes to mind AND WHEN I READ YOUR POST I FELT LIKE THIS
post #6731 of 10036
I think you need to reread the post, he's asking if it would bottom out using the config in the post.. not that he's bottoming out atm.
post #6732 of 10036
I've read it carefully and this was his last statement Doubt it will bottom out so easily even with this setting?! Also on a side note from reading some of his posts I dont think he even owns a SVS so im not really sure what his motive is . Why would he care about tuning if he doesn't own one and yet wants a comparison between a plus and a pb13 and also asking if the pb 13 wouldnt bottom out so easy with a different tune . If he thought the PB13 would bottom out so easy why would he even want one let alone go to a smaller sub the plus and BTW dont know if you own one but they definitely dont bottom out easily and I know from first hand experience being a owner with proper setup/room and common sense it wont happen and you'll have subsonic bass more than you could ever ask for, i've never come close to bottoming out my plus or pb13 . So I dont know you tell me does he own a SVS or is he just curious about running different tunes on a sub he doent even own ?
post #6733 of 10036
I believe it was just a poor turn of phrase. I thought he was comparing against two options (either as an intellectual exercise or as a purchase decision) and was wondering if removing the subsonic filter would increase the capabilities of the sub. I read his statement more along the lines of "Even if I were to change the settings to deactivate the subsonic filter without the ports plugged as SVS suggests I do not think I would bottom out the woofer due to its abilities."
For the record I wouldn't recommend trying to test out the theory too thoroughly as it could lead to damage to the driver, and those can get to be pretty pricey.
As for if he owns one or not, does it really matter? I think about equipment all the time from other manufacturers and what they may or may not be able to do. Daydreaming about audio equipment has helped me survive some pretty boring lectures.
post #6734 of 10036
When playing with different tuning options I first turn off any EQ and then readjust the level of the sub trim in the AVR or if it is to be an extended audition I rerun the EQ and verify the post EQ levels. The output of the sub, as well as its -3db point, will change between the different tuning options. Both areas should be addressed for a fair idea of the tune.
post #6735 of 10036
Theres always two sides to a coin and you've made some good points and I guess your wright it really doesnt matter if he owns one or not and maybe he is just bored. I'ts been a month or so but I posted some pics On a thread I believe of my pb13 and my plus and I think he had posted a comment how he didnt like the color of grill and or the port plugs lol so I guess he must be board lol . But hey thats what makes forums so great you get every walk of life and so many different oppinions
post #6736 of 10036
Greetings to all SVS owners/members.I've recently purchased the PC ultra -13
post #6737 of 10036
Wow very nice and congrats ! I've always liked the looks of the pc Ultra line. Thanks for sharing the pics .
post #6738 of 10036
Impressive,whats that P-digm gear you have .Is that really you on that bike?
post #6739 of 10036
Thankyou There the studio reference v4 60's front left and right, the center is a v4 cc-690, sbr adp470's . Yes thats me and my bike its a 06 Honda cbr 1000rr at Portland international raceway . I also ran it in the 1/4 mile 10.2 @ 140mph trap speed, its a real fun bike
post #6740 of 10036
Aren't most dacs at around 20hz on the lower end?
post #6741 of 10036
Two SVS subwoofers.
Chuck
Congrats on the new addition. Any lower hz you are feeling is made possible by your new ULTRA.
Not only does it go lower, but it is tighter and more accurate.The PB13 ULTRA's mid bass punch is unbelieveble.
It is their fastest driver yet. It is made this way, as per Jack at SVS, "It's actually a stitched foam-core/glass composite for even more rigidity"
I guess that is why it is so darn pretty.
post #6742 of 10036
I have no idea but if I were to speculate, the DAC responsible for subwoofer would have to go lower, otherwise how would you ever get below 20hz?
post #6743 of 10036
Now we must research.....
My Onkyo's freq respon. is 5hz to 100khz.... Maybe under 20hz it passes it through un-molested?
post #6744 of 10036
Hey guys hows it going?? Just moved recently and the place where I have my PB13 is not that good. When I sit way back in the room where my computer is I hear way better bass and the vocals and everything just seem a lot better. My Computer is about 5 - 6 feet behind my main sofa listening position. When finding a place to put the sub is the crawl test good?? I also have a radio shack meter.
Can you guys recommend a good Test CD that I could use to find a good position??
At the moment I have Klipsch RF-82 on each side of the TV, RC-62 Under TV, RS-52 Surrounds and RF-15 Rears. I think I may have to move the surrounds forward a bit. Right now I put them a couple feet forward of the couch on the side walls. Here are the dimensions of my room, 14'x14' then behind that its 10' x 14' all open but in the middle is a fridge and a bar type thing where I have stools. Then theres a little hallway to the bathroom and a door way to bedroom as well which can be closed. Thanks
post #6745 of 10036
Since you have your computer in the room, I suggest you get the free software program Room EQ Wizard. You hook it up to your SPL meter, as well as your receiver, and can instantly run frequency sweeps to see where the best response is. Put the sub in your listening position and move the mic around, taking different measurements. The smoother the response, with the least amount of bumps and large peaks, the better.
Also, it's possible that your speakers aren't properly positioned if they sound better further back in the room. Try toeing them in towards the listening position more. Different speakers sound better at different angles, but you can experiment with that with some music that has a few instruments and a solid vocal. When you aim the speakers right, the vocals should make a clear and concrete image in the middle, instead of sounding like the vocals are coming from the two speakers on either side. Something like Norah Jones or any good vocal jazz or acoustic / folk CD, where you can concentrate on the vocals without a lot of other sounds cluttering it up.
post #6746 of 10036
Just a data point for anyone who is interested.
Earlier in this thread I asked about the effect of DACs on the subwoofer frequencies.
Although I can't say for sure if it were the DACs or not, changing from my B&K Ref 50 prepro to the Integra 80.1 had a major change to the sound of my PB Ultra 13. I did run Audyssey on the 80.1 but even without Audyssey engaged, I thought the two prepros changed the sound on the Ultra 13. The 80.1 made the sub sound more precise.
The sub was not moved and was level matched to the same +3 dbs.
Obviously changing subs causes a change in sound but now you have to consider your prepro/receiver too.
post #6747 of 10036
I e-mailed Onkyo and they said they do indeed affect the sub frequencies. So that would explain your experience.
post #6748 of 10036
Don't need no more!!
post #6749 of 10036
Very nice Rampage !!!
post #6750 of 10036
Umm... wheres the TV?? Did it explode??
