AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official SVS Ultra 13 thread
Official SVS Ultra 13 thread - Page 273
post #8161 of 10035
Originally Posted by Ron Temple View Post
If I'm reading this correctly, the Sledge amp can be heard while the sub is inactive. Is this a humm or buzz? Groundloop?
It's a rather high-pitched pink noise.
SVS is aware of it, but they consider its level acceptable.
post #8162 of 10035
Does the amp itself give off the noise or does it send it through the driver? If it sends it through the driver, it could be stopped by using the sub's crossover unless it originates after the crossover stage.
post #8163 of 10035
Originally Posted by LeoB View Post
If you don't hear the noise two feet away from the sub that's fine! In my case the noise is limited to the same distance with the BASH amp, but with the Sledge I could hear it from 14 feet away over the noise of my HTPC and plasma TV (muted) running at the same time. Buy the way, the noise I'm talking about is independent of the gain control.
So you are hearing noise from both the BASH and the Sledge amps? That almost seems like it's coming from something external to the amps.
post #8164 of 10035
All of mine make that sound as well. I have power conditioners and a ground loop isolator for the buttkicker. It's not the signal being sent to the subs.
post #8165 of 10035
I can gladly say my Ultras don't have that issue at all.
post #8166 of 10035
Mine all make a sort of 'wind tunnel' noise.
post #8167 of 10035
I think that's a separate issue.
post #8168 of 10035
Dude that's the least of my issues lol.
post #8169 of 10035
I can barely hear 60Hz hum no more than 1.5-2 feet away from the sub with the BASH in it, and I could hear that pink noise about 14 feet from the sub with the Sledge in it. The first thing is fine with me, the second one is not.
post #8170 of 10035
Mine are quiet
post #8171 of 10035
Originally Posted by rampage123 View Post
Mine are quiet
x2 both my plus and my ultra ...............KNOCK ON WOOD !
post #8172 of 10035
It sent it through the driver.
I guess that noise came as a side effect when SVS tried to squeeze extra 200W from the amp originally designed to produce 800W.
post #8173 of 10035
Rampage and TheFactor, it seems you have missed my point - only the subs with the Sledge amps are affected by this "noise problem". I think both of you have BASH amps.
post #8174 of 10035
Are you the only one here so far with the Sledge amp? I find it difficult to believe SVS would call any amount of "noise" coming from the sub detectable from 14 feet away "within acceptable limits".
post #8175 of 10035
I also just got a PB 13 ultra in black oak with the sledge amp.
I acutally had the PB 12 PLUS and upgraded to the 13.
I have not done fine tuning and such yet but at moderate to higher listening levels there doesn't seem to be a huge difference.
I have not tried giving it closer to its max output yet as I would like to work the unit in first..
Someone posted they would like to see a picture of it... I will try to post it soon. It looks a heck a lot better than the PB12 plus that had the laminate or whatever you call it on the top and oak only on the left.
The whole cabinet is covered with the black oak... Matches my Energy RC-70, LC-R's very nicely...
It is quite true that I can't compare the impact of bass to my Image Dynamics IDMAX 12 in my hatchback car as generally tuning on the ported boxes are higher e.g. 26-40 hz vs home theatre below 20hz...
Although I am surprised that 1000 watt RMS on the pb13 plus does not seem to move the xmas of the speaker as much as my JL Audio 500/1 DC amp... eh... complete different comparison..
Do people generally leave all the settings flat? and just change the Volume?
I did not play around with any phasing, or PEQ 1/2 ...
post #8176 of 10035
I ordered my sister 2 Pluses with the sledge amps in the last month and she tells me they're quiet.
Each of my individual Ultras and Pluses are rather quiet, it's just that there are six of them in a small quiet space and my ears are rather sensitive perhaps.
post #8177 of 10035
When you say "small", how small?
post #8178 of 10035
12x12x7 sealed.
post #8179 of 10035
12x12x7 sealed.
With 6 subs in a 12'X12' room, I think I've determined why you don't hear a hum.
post #8180 of 10035
Congrats on your new sub. can't wait to see what that black oak looks like. hint hint
post #8181 of 10035
Originally Posted by princenk007 View Post
............ I am depending on the forums to get the justifications for my future sub. since there are no authorized SVS outlets available in my country India, i can't get any demo's of the ultras or experiment with them. All the forum reply's and posts will be the guidelines to me. Thank you people for your interest in reply!
Hsu has an authorized dealer in India.
http://forum.hsuresearch.com/showthread.php?t=30334
There are many boutique A/V stores if you live in a large metro like Bombay or Delhi or Bangalore. They will resell you practically anything.
The problem with "electronics" is that they need to be compatible with 220v/60Hz. The bigger problem is that they need to be tropicalized that means they should work with the 100% relative humidity and 30 C heat that will exist during the Monsoons.
Unless you have a HT setup in a room with A/C (humidity control) you can quickly end up with a 50kg paperweight.
So be careful about what you buy and how well it is supported.
Also with the 100% duty on any legally imported electronic product you are looking to pay double of what a Hsu VTF-3 Mk.3 would cost in the US. But at least it will be support.
post #8182 of 10035
100% duty......all together..... uuugh
post #8183 of 10035
Yep, import duty is pretty steep.
Well I am hoping that some of you SVS owners can help ME out.
How on earth do you transport a PC13 Ultra when the original packing is not available? It's a 5-10 mile drive on a freeway. So can I just lay it flat on a truck bed? Or does it need to be transported standing up? I am pretty sure it wont rain but it will be exposed to the elements during the drive.
Also HOW do you test the PC13 when its not connected to an amp? Can I carry test tones on an iPod and connect the the iPod via line level inputs to play the 20-200Hz sweep and other tones? Will that be as effective as a HT test CD?
post #8184 of 10035
You can lay it flat, just put some blankets under it and tie it so it can't roll. Maybe cover it with plastic also.
post #8185 of 10035
...snip...
It has a built in amp. You only need to send it a line level signal.
I was going to suggest a laptop with an external sound card. Don't have an iPod but it sounds like it might work.
post #8186 of 10035
Surfing You Tube Vids, I saw car/truck/van audio systems with for example, 8 18" drivers, 24 10" drivers etc. All driven with several thousand watts (multiple amplifiers) DB in excess of 150. I thought I had a pretty big home stereo system, until I saw these extreme systems.
post #8187 of 10035
rampage,
In car audio competition, isn't it all about SPL?
If you remove half those drivers and power, you're only dropping 3-6 dbs.
post #8188 of 10035
Originally Posted by JimP View Post
rampage,
I suppose it would.What is it,2 times the amplification for each 3 db increase?
post #8189 of 10035
Right...then another 3 for close proximity...sometimes.
post #8190 of 10035
Ok then for example say 89 db sensitivity at one watt, then what would these 30,000 watt systems do. Also their multiple drivers are very close prox. Like 4 rows of drivers times 6 per row.
To answer my own question, a speaker with a sensitivity of 89 DB at one meter with a one watt input......., would produce 134 DB at one meter, with 32,768 watts!!!! (doubling the wattage for each 3 DB increase)
My mains are 89 DB/one meter/one watt. My two mono amps are rated a @ 300 watts each ( I'm using one amp per speaker) . So If I'm correct the most I could get is 113 DB @256 watts input at one meter. Is this correct?
