AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official SVS Ultra 13 thread
Official SVS Ultra 13 thread - Page 325
post #9721 of 10029
Originally Posted by KevinG View Post
I left my pc13-ultra at -20db (in fact, I didn't change a single setting from the OOTB settings)
YPAO sets my sub at -0.5db, and I always have to give it 3 or more db "extra" to actually sound like a sub should sound IMO. (I've also verified with a meter that adding 3 or so db gets me closer to reference)
-Kevin
If you regularly listen at loud to very loud levels, then I recommend setting the subwoofer gain to -10 (a 10 dB gain) and the Yamaha sub channel level to -10.5 (a 10 dB drop). While the overall calibration level won't change, the amp will make more peak power the closer to 0 dB the gain is set.
post #9722 of 10029
-Kevin
I recently moved some stuff around (which necessitated a re-calibration via Audyssey), and bumped my 2 PC13's up to -10 (from -20), and the AVR trim down to -8 (from +2, which equates to 3dB above flat). The resultant bass was definitely smoother, and more authoritative.
post #9723 of 10029
Good move - with the Sledge 800/1000 platforms, the higher the amp gain you can run (while still maintaining your overall calibration level by lowering the AVR sub channel level), the better the amp will perform.
post #9724 of 10029
Just wondering: if I bump up the sub gain by 1 on sledge, does it mean I can balance it by decreasing the AVR sub level by -1dB? Or should I rerun Audyssey every time I change the sub gain?
post #9725 of 10029
Yes, exactly correct. It's a 1:1 ratio. No need to re-run Audyssey; it will maintain the overall sub channel level.
post #9726 of 10029
Ah, excellent....I'll do this tonight...thanks for the advice!
post #9727 of 10029
Best advice I've found on here in a while! I just went from -16 to -6 on my PC13-Ultra and from +2 to -8 on the receiver. Played some Massive Attack tracks and I am definitely liking the change.
I have an AS-EQ1 as well, if I re-run the setup in the future, should I leave it at -6 dB or set it back to -16 dB where the software measured 75 dB in the room and just change it after?
post #9728 of 10029
^^ now that I didn't know
I've been running my SVS at 1/4 volume
post #9729 of 10029
Hi Ed, does this also apply to the BASH 750 amp?
I know that without the convenient digital display it's hard to know by how much you are increasing the amp gain, but just wanna know if the same principle applies. I can use a SPL meter to check the level.
post #9730 of 10029
I'm interested in the answer to this also.
And a second related question, if I like to run the sub hot (say +3dB) post-Audyssey, should I bump it up in the AVR or at the sub amp?
post #9731 of 10029
In thinking of buying a PC13-ULTRA but im a little concerned about the "white noise" issue. I recently sold a PC12 Plus and it had this issue.
post #9732 of 10029
can I check please that running the sub at a lower port setting on the rear - than the physical configuration is ok ? (I think it puts less strain on the Sub anyway ?
ie:
2 Ports Open (PC-Ultra) - 15hz tune
amp panel set to 10hz tune
it just seems to remove a big room boost around 25-35 hz that room size doesn't correct - small/medium/large seems to have more effect lower down in the spectrum - sub 18-20hz
thanks
post #9733 of 10029
I'm starting to think the obvious answer is yes. There is no way I would read 75 dB at the new level when I take the first measurements.
The best change I've noticed is when listening to music in Direct mode.
post #9734 of 10029
ie:
thanks
Not OK - this leaves the sub unprotected from frequencies below tuning. The ports unload below tuning frequency leaving the driver with little resistance to bottoming when the subsonic filter is set lower than physical tune.
Doug
post #9735 of 10029
Doug
ah ok thanks - I thought it was other way round - I thought setting the subsonic filter to a higher frequency than the actual port tuning was bad
post #9736 of 10029
just re-read the manual and you are quite correct you shouldn't set subsonic filter lower than port
thats surprising as if anything in that setting it seemed to be cutting quite a lot of bass - but I'm no expert - its a pity as gave me a nice flat response - never mind - I've reset it back to be the same as the port
post #9737 of 10029
i don't know which sub you have, but you might be able to tune it lower than 15 Hz (my PC12 Plus can be tuned to 12 Hz and the filter at 11 Hz);
this also could lower or flatten your bump.
it's worth a try.
post #9738 of 10029
The original generation Sledge amps had a higher noise floor than we preferred (it was tied to the input sensitivity and associated signal/noise floor). This was corrected in subsequent production runs and the lower noise floor amp has been in circulation for a few years now. While all amps have a known S/N ratio and an audible noise floor, the improved version is very good and we've had no issues or complaints about it.
post #9739 of 10029
I'm having a problem with the shipping cost on my ebay auction of a PB ultra 13.
How have you guys been getting delivery of your PB Ultra 13s?
Thanks in advance.
post #9740 of 10029
Thanks in advance.
PB13-Ultra's shipped in the US go motor freight - RL Carriers.
Cheers,
Doug
post #9741 of 10029
Doug
A major thanks.
post #9742 of 10029
Hi Ed, I am also wondering if this applies to the BASH amp?
"the higher the amp gain you can run (while still maintaining your overall calibration level by lowering the AVR sub channel level), the better the amp will perform"
post #9743 of 10029
Mitch,
If you're up to experimenting, rerun your system so that your final subwoofer level in your preamp/receiver winds up at -4. At one time, that was considered optimum for giving your headroom in your preamp/receiver and a high enough signal to your sub so that the auto on would come on.
post #9744 of 10029
The BASH amp has an analog gain stage which functions totally differently. It is not sensitive to gain setting and can be driven to full power at much less than full gain. So with the BASH, I prefer to just set the sub channel level somewhere around -5 and then adjust the gain until you obtain the desired SPL.
post #9745 of 10029
Hey Ed. I'm a SVS customer(2 CS Ultras), any chance of buying a Sledge 1000 amp to replace my old Sampson?
post #9746 of 10029
Thanks in advance.
It is free to Louisiana (iwish) Hello JimP.
post #9747 of 10029
The Sledge 1000 cannot drive both amps at the same time, unless they were wired in series for an 8 ohm load. The amp wouldn't make full power into that load, but that's not necessarily a bad thing considering the application.
No promises but send us a note to custservice@svsound and we'll at least kick it around.
post #9748 of 10029
Thanks Ed!
post #9749 of 10029
I did it exactly that way and been enjoying it for a more than a year now. I still like this beast very much. Never fails to impress any visitor
post #9750 of 10029
Question for the owners!!
I've never heard a 13" sub, is that the best of both worlds? 12 + 15 subs are both great and sound so different, sites this sub play a sound somewhere in the middle. Thanks for any info or a link to it
