AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Cables and power cord coming out of ceiling???
post #1 of 4
So....Do most of you bundle your power cord coming out of the ceiling outlet with your video cables going to your projector in one bundle for neatness? Is this a good idea as far as electrical interference goes. Should you keep them seperate even coming out of the ceiling? Just wondering?
post #2 of 4
I kept mine separate to reduce interference. I have electrical in one joist cavity, and low voltage in the next one over.
post #3 of 4
Kept mine separate too.... Also in different joists, and coming from different directions. If you look close you can see all the signal lines are bundled together. The bundle comes out directly behind the PJ mounting post. (from this angle it looks like it's right next to the silver PJ post),,, the other is the single input AC line.
post #4 of 4
That's what I was looking for....Thanks!
