AVS › AVS Forum › Video Components › Video Processors › New DVDO iScan VP50PRO
New DVDO iScan VP50PRO - Page 176
post #5251 of 5883
Originally Posted by Gary Murrell View Post
no, doesn't work that way at all as Josh said
the decoder will determine the SDI image quality, that is all there is to worry about with a SDI player PQ, decoder quality varies wildly between makers some reduce noise slightly, others tweak gamma, some have chroma bug issues, some are perfect etc.
the Panny/Oppo decoders are at the top of the game
-Gary
Ah. Makes sense. I had assumed that MPEG decoding simply worked--it is after all just an algorithm. It shouldn't vary from one decoder to another, but apparently it does. Thanks for clarifying!
post #5252 of 5883
far cry from how things used to be
not good!! it would be wise to keep in touch with your pickiest hardcore videophile customers like those on AVS
-Gary
Totally agree. They said it takes up so much of their time, and they have normal support to take care of. Seeing how much time I spend just reading these forums, they have a point.
post #5253 of 5883
You can pretty much bet that if they were coming out with a new product to replace the VP50Pro. That they would have no problem in finding the time to be here on a regular basis for at least month or so to try promote sales for it, and to try and get people into trading up for it.
For me, I think the VP50Pro is going to be my last trade up with them, and probably also my last stand alone DVDO product. I started out with a VP30, did the add-on that there was for that with the 102 card, then traded that up to a VP50, then traded the VP50 up to the VP50Pro. And none of them were really ever fully supported with enough firmware updates, to where all their bugs/problems were fully fixed or cured.
post #5254 of 5883
And they would probably get the verbal beating that they so rightly deserve.
post #5255 of 5883
Speaking of bugs--I'm seeing a weird thing with the Info display.
Configure two presets: preset 1 and preset 2. Make sure they are obviously different from one another--for example 4:3 vs. 16:9. Don't use the *predefined* presets--define your own.
Configure four display profiles, 1-4. Again make sure they differ.
Set preset 1 and profile 1, see what Info says.
Set preset 2 and profile 3, see what Info says.
When I do this, the second look at Info displays preset 1 and profile 3, but when I go into the Menu to see what is actually set, the preset is clearly 2, not 1, and because the presets are very different, it's also obvious onscreen.
Does anyone else see this behavior?
post #5256 of 5883
if the Radiance had 2 or 3 HD-SDI inputs I would jump ship for sure, really sad
-Gary
post #5257 of 5883
I hear you. I've been a long time DVDO owner myself. Upgraded more times than I'd like to admit.. I wish the VP50Pro had a full CMS and improvements in the RGB Gain/Offset for additional tweaking of my display. All I've ever heard is "they are working on it"....
post #5258 of 5883
the greyscale stuff is pathetic really, the capability is sitting right there for 10 or 20 point greyscale control, just a little bit of coding, I just don't get it
here is what would make me happy to stay with DVDO:
greyscale control at 0-100IRE points, 10 at minimum
color/hue control for all 3 colors to correct decoding errors and colorspace conversions that happen in some gear(like the Dish 722)
separate blue/red Y/C delay controls
virtual inputs per input
gamma control at 10 points or so
CMS I guess, I don't need it but many do
-Gary
post #5259 of 5883
One more reason for me to be happy....I don't have to be that person
post #5260 of 5883
Originally Posted by gulliBELL View Post
Excuse my ignorance but I've been away for a while...what happened to Dale, did he leave DVDO?
Originally Posted by aaronwt View Post
A long, long time ago wasn't it?
He certainly seems to not post here any longer, but did he leave DVDO again? He came back about a year and a half ago according to this post by Josh.
http://www.avsforum.com/avs-vb/showt...4#post13040204
- Collin
post #5261 of 5883
I hope Dale has'nt left DVDO again If so there goes our chance of getting A decent CMS/ Gray scale/ and Gamma implemented into the VP50pro!!!!...
Cheers....
post #5262 of 5883
Has anyone tried this? I can easily reproduce this bug, but DVDO says they don't see the problem. I have the latest firmware.
post #5263 of 5883
I've been planning to get our 141FD display calibrated, and I noticed in the manual for the VP50 Pro that it also has ISF modes that can be set by a calibrator.
Is the typical approach to calibrate the display and ignore the ISF modes on the Pro? Has anyone gotten both calibrated? Does anyone leave their display uncalibrated and calibrate using the Pro instead?
post #5264 of 5883
As far as I know, nobody even knows how to enable the ISF modes on the VP50Pro. I would guess that you would also need something like ControlCAL to do that, just like you need it to enable the ISF modes on the Pioneer Elite 9g plasmas. And so far it looks like ControlCAL does not offer any support/profiles for the enabling the ISF modes on the VP50Pro.
post #5265 of 5883
I have the ISF mode permanently enabled. If I remember correctly you need to enter the ISF menu first then hold the power button down for 5 seconds, that should enable it. I will check tonight and confirm.
post #5266 of 5883
Very cool--I'll take a look.
post #5267 of 5883
But the ISF menu is greyed out. What do you mean with "enter the ISF menu"?
post #5268 of 5883
Maybe the menu where the ISF options are located (even though they are greyed out). I'll try it today. SJ
post #5269 of 5883
Go to picture control, select preset, access ISF menu that is grayed out, leave cursor on preset 1 and then hold the power button on the unit (not remote) down for 5 secs, when you return to the ISF menu they will no longer be grayed out. I just did this to confirm that it works.
post #5270 of 5883
Maybe if I hold down the power button for 5 second while over the picture settings it will engage a full CMS. Also, if I hold it over the RGB (gamma), it will engage more options for tweaking my greyscale...
post #5271 of 5883
THX! I'll try it out today.
post #5272 of 5883
i just wanna get more informations about videos and movies and so on
thank you for telling me anybody
post #5273 of 5883
What additional adjustments are available there? I was under the impression that it just allowed the storage of (more?) profiles.
post #5274 of 5883
I just setup an Oppo BDP-83 (fw May 4, 2009) and a Onkyo PR-SC886P (fw 1.05). I cannot get the VP50Pro (fw 1.05) to pass DTS-MA . Anyone have any experience with either of these units and the VP? I have seen some people using the BDP-83 without any mention of issues. Is the VP likely at fault? Are there any tricks that may help?
post #5275 of 5883
Correct.
post #5276 of 5883
You wish, actually so do I!
It's almost as if Anchor Bay has completely forgotten about this product.
post #5277 of 5883
I have a Pioneer BDP-09, a VP50Pro, and a PR-SC885P (in that sequence). You must have firmware v1.05 (latest) to get the VP50Pro to pass DTS-MA.
But mine works great.
post #5278 of 5883
I have the latest firmware for each device. LPCM and Dolby TrueHD work but not DTSMA. The VP50Pro says non-pcm but the onkyo shows no signal.
post #5279 of 5883
Have your tried plugging the Oppo directly into the Onkyo? Tried both cables to check those out?
post #5280 of 5883
I run an OPPO BDP83 into my VP50Pro and then into my Denon AVP-A1HDCI. Passes everything (including DTS-MA). The only exception has been DSD for SACD. Although it does pass multi-channel PCM for SACD which sounds great. SJ
  Back to Forum: Video Processors
