Originally Posted by
TomHuffman
Presumably, on less-than-perfect SD sources that would benefit from noise reduction and detail enhancement the answer would be "yes". On high-quality HD sources the answer would probably be "no".
not the case at all Tom
the VP50pro NR, Detail and Edge enhancement controls are a thing of beauty
let me explain, as a user of a CRT projector I am always looking for just that small extra pinch of sharpness, but 100% natural at the same time, on the other hand I hate edge ehancement and ringing
, which is the offset of adding a pinch of sharpness, so basically you can't add any details/sharpness without pissing me off
not the case anymore with the VP50pro, with these 2 amazing controls, you can add a pinch of sharpness via Detail enhancement and then take the Edge ehancement control into the negative to get rid of the ringing
, the result is a smooth filmlike image with just a pinch of extra detail, it is literally amazing to say the least and this is with any source and I mean any
with the NR, Detail and Edge controls and their positive and negative range on the later two, you can work wonders with any source and that source's material, these controls are not childs play, they are the real deal
the pro is an amazing upgrade over the 50 with all source material, if not why would DVDO bother?
-Gary
