I have only skimmed some threads here but it is a huge forum. Using (mostly) the directions on Engadget, I built a nice screen : http://www.engadget.com/2006/08/29/h...jector-screen/
I am quite happy with the way the screen turned out. I used the shiny side of the blackout cloth as I thought it looked 'whiter'. However, with my Samsung H710AE, I have to wonder if I need a higher gain material. I don't know what the gain number is for the blackout, so I can't speak in specifics here, maybe someone can help out with that too.
I'd like to retain the frame that I have, as the size, weight and portability work fine for me. I cannot go much heavier than this as the screen will need to be moved occasionally due to a pair of closets in the wall behind the screen.
Will using Behr Silverscreen on the cloth make an improvement? Some sort of coating is the way I'd prefer to go as my kids and I spent a fair bit of time stapling and gluing the blackout cloth, then attaching a felt border, etc.
