Are you sure you are in the SM? If so, what are all of the menus available for you there?
I honestly would not equate what a pro does with what I might do!!
The HLTs are a little different than the HLS
The HLT models have a Desaturation menu in addition to the CCA menu. It has xy coordinates for primaries and secondaries called "Normal" and another set called "sRGB". You can calibrate "normal" to rec 601(SD) and sRGB to rec 709 (HD). Initially sRGB is close to Rec. 709. Start by inputting the expected values for the primaries and secondaries for each standard in the Desat menu. Then turn CCA off then back on for your change to take effect. If you want to copy this to other inputs, WB spread. This will get you close. You can then tweak the coordinates in the Desaturation menu in the SM to get all coordinates to line up with the CIE coordinates like this: Note: SM default is Dynamic Cool1 for white point 1. CCA on 2. Measure primaries/secondaries 3. Calculate x and y delta from nominal 4. Change x and y by that delta in Desaturation menu 5. CCA off 6. CCA on 7. Re-measure 8. Repeat until all primaries and secondaries line up 9. WB spread to copy to all inputs You can use continuous reading to help if you have SW that does this. I am sure you can probably tweak the CCA values to accomplish this as well. I have not tried that yet. It would be faster because you could see the effect of your changes by scrolling up or down to the next data field in the CCA menu. Done? Nope. I found that when you exit SM and measure in the user menu that things are off slightly. Don't know why. User mode will be Dynamic If you didn't set contrast, brightness, color in SM do so in user and note your settings. 1. Measure primaries/secondaries 2. Calculate x and y delta from nominal 3. Enter SM 4. Change x and y by that delta in Desaturation menu 5. CCA off 6. CCA on 7. WB spread 8. Exit SM Go into user Enter calibrated user settings if needed Repeat steps 1-8 until everything lines up. Write down all original values, tweak at your own risk, and good luck. I have noticed that the color decoder does not seem quite right. I do not know how to tweak this. The luminance values for RGB are not right when compared to what they should be to comprise white. You can tell that I do not write tech manuals for a living but I hope this info helps. |
