AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Think I've decided...
post #1 of 3
Hello all again. I've narrowed it down bewtween BIC H-100 and the eD A2-250. Question is, where can I learn more about calibrating a sub to a room? I know nothing about nulls and spikes and all that. Can you direct me to a site with the information? Thanks in advance.
post #2 of 3
well calibrating can be hard if you don't own measurement equipment, but with a little patience it can be quite good anyway...
start with seating your subwoofer in your listeningposition, then you start walking around in front of your listeningposition and try to find a position where you like it....that's more or less where you want to place your woofer...though a corner positioned subwoofer will ha significant lower distortion than a placement in the middle of the room...
when you settled where to put your sub you need to level it with your other speakers....put the volume for the sub at 0...and slowly start cranking it up until your bass takes "over" the music.....then you start lowering the volyme of the sub until you can't identify that it's really playing...
closer than that without measurment is impossible....
if you have tops and nulls in your room you should take a look at some acoustics either on the dedicated home theatre part of this forum or at my website (signature)
post #3 of 3
You'll need an SPL meter (the cheapest, simplest can be readily obtained at Radio Shack) and plenty of time and patience.
There's plenty of good info on subwoofer setup basics on Audioholics. Try the link below, it should get you well on your way.
http://www.audioholics.com/tweaks/get-good-bass
Scott
